LS6 oil pump...
I'm just looking to put an updated pump in it when I do my cam swap, I can't justify a ported one from one of the vendors right now.
This issue has been a pet peave of mine because there is such a thing as having too much oil pressure and yet no one has been able to document any LS1/6 engine failure as the result of not having enough oil pressure. However, I have seen a number of posts on this forum regarding problems that people have caused themselves after trying to install a new "LS6" oil pump.
Many people have posted on this subject, if I were in the business to sell parts I don't think that I would be too eager to tell anyone that they didn't need my product....
THAT is why I "think" I need a new oil pump. It's cheap maintenence, my car has great oil pressure currently, but I don't think a new oil pump is over doing it while I'm in there changing the cam. My car has 74K miles and I add to it by the day, I'm sure an oil pump can't hurt.
As for needing an oil pump after only 74K miles I suggest you save your money. I agree with ChucksZ06, the risk of screwing something up while changing an engine component that is working perfectly fine is a risk that should not be taken. I have personally never seen or heard of a catastrophic oil pump failure on an LS engine, it's not like the old days when pump rods would break or pickups dislodge. Were it not for all the "LS6" oil pump hype people probably would not even consider this action in the first place.
Part: 12586665
Category: Engine Oil Pump
Description: PUMP
Min.Qty: 1
Unit Price: $61.75
Quantity: 1
Ext.Price: $61.75
Core Charge: $0.00
remember that GM "declares" many diferent P# from the very same casting.
I mean that the raw casting (#casted) is diferent from the next machining step, then a diferent # is "declared" after assembly and so on, and to make maters worst (at least for us trying to make sense of the numbers) the P# generator is RANDOM!
for the pump, I bought one in ebay ported and polished, and still have doubts, for installation oyu have to dissasemble the pump and slid the gerotor in the timing snout WITH (I think 2mils) of clearance each side, lube gerotors in 90 (!) oil (I think this is for guarantee sucking power when first fired) and my pump came with stock spring presure (I double checked) so I opted for putting two SS washers in the cap for increased preload on the spring, locktigthed everithing (BTW from the porting shop mine came with one striped bolt... SHAME ON YOU!)
and worked absolutly amazing, almost no delay in oil P at startup a very faint tickling from the filling lifters for about 2 seconds, and the oil P (indicated) at iddle was 3/4 of instrument pannel, (Vs half from stock) this was all at start up (cold)
the casting constraints made it to have lots of internal turbulence that worsens the efficiency.
and YES, **** in the oil, or even worse SHITTY CHEAP OIL!!!!!
