MTI X1 Cam Guys,What is you Total Timing up top?
I think my tuner went with way to much timing on my LS1.Mti said an average timing with X1 Cam and 2E Head combo's is 24-26 degree's total advance and No More than 28 Total advance.My car is getting 29 from 6000 up.I am not getting KR @ WOT but I am curious as to am I losing power?Is this to much timing?What timing are you X1 cam guys seeing at upper Rpm range?
Thanks!
Scott
Thanks!
Scott
I have the X1 in a cam only set up. My ignition advance is around 21 from 4,000 to 5,500 and around 23-24.5 from, 5,500 - 6,500. No knock retard.
Sounds like you could be a little high, at least compared to mine which was tuned by MTI. Also sounds like I might be slightly low...
