Heads for my 402 needed AFR ?
Yeah I ordered them with the spring upgrade. Tony is going to figure out a good cam profile for me to run and I may go with that but it will probably be over .600 lift anyway so the spring upgrade will be good to have.
(Classic Morpheous line....)
It was good speaking with you today....let me know about some of the other small details we spoke about, and when your ready we will get that custom cam in the works as well.
Just think, with all the time you have before the heads are finished you can work nights to pay for that FAST intake which we both know you want and will ultimately own.....
Sure there is.
If you beat me your too fast and need to slow down so I can be the fastest, or give me your car and then it wont be too fast.
I will do it for you.
Were gonna use a .040 gasket and go with a avarage deck height.
I get 10.54 CR and 414 cubic inches.
Mill those to a 68cc head and you have right at 11:1
http://www.rosspistons.com/calculator.php
Here is a common example to help you start. We will use a stock LS1 motor.
Bore (inches) 3.898
Stroke (inches) 3.622
Head (cc's) 66.67
Gasket Thickness (inches) .054
Deck Height (Put .0001 for zero deck) (inches) .007
Dish or Valve Pocket [-] or Dome [+] (cc's) 0
Number of Cylinders 8
345.79 cubic inches and 10.01:1 compression.
