FM13 Just Installed Great Dyno Numbers BUT!!!
Originally Posted by ChucksZ06
ls6 blocks have larger openings between cylinders in the main web area for better oil control at high rpm and therefore produce a little more hp than earlier ls1 blocks. Some 02 camaros came with the ls6 block.
All you need to do is lower the main ve table on the 400-800-1200 columns. Set the idle to 850 rpms. I think I pulled out about 9% on the main ve table on buddies car. Idled good with those changes.
As for the cold start issue, is your throttle body stock? If not, pull it and make sure the hole for the IAC motor is atleast 3/8" or better yet 1/2". I had a throttle body with very small IAC hole, once I drilled it out, idle and surging went mostly away, and what was left was easily tuned out.
Originally Posted by WS6FirebirdTA00
hye man i went to drill mine out and it didnt go so well, long story short i have no filling at all now lol
Hopefully at least it idles like a champ now, no?
You had the copper tubing in there, no? Anyway, why not re epoxy it now? Make sure you score up or better yet notch and knurl the area where the epoxy needs to stick to. I used plumbers putty to take up the bulk of the space by laying some about the size of a pat of butter. I then lubed up two pens to make the holes (you may want to use a marker for the IAC) and then put more plumbers putty in there to get the basic shape. I then pulled out the pens before it hardened. After the plumbers putty hardened, I filled the rest in with JB weld, and once that sat overnight, I have it a last touch up with the dremel.
i might not even fix it, i have a thread about this and they said gains are minimal, bit if i do it again ill make the hole size the max effective area. i wanna have a car that starts good whne cold so people dont look at me like what hte hell is going on with your car lol
#34
Originally Posted by Evans752
I just recently installed F13 on 112+2 and it dynoed great. I had a friend of mine tune on it and it still has a real problem Idling on cold starts and I can smell it still running rich at idle. It Dynoed 422rwhp and 389rwtq and it showed a 13.0 afr at wide open. This was done on a Superflow dyno. I am thinking of taking the car to Alan himself and getting itn lined out. All mods are in sig.
#36
my car doesnt smell bad and i have no cats and my cam is NOWHERE close to being bad at idle, same cam he has, so i have to disagree with you on that one
#38
Originally Posted by stang killer
Im just going off personal experience, i havent came across a cam car here in texas that didnt have a smell to it.
I also have the same cam, and once I ironed out all the bugs and got a decent tune, I dont have much of any of these problems.
