trying to pick head/cam combo for 383 LS1
i'll also have a F.A.S.T. LSx intake manifold with 90mm TB
need some ideas on pretty much everything and any direction would be greatly appreciated....this motor will be going in my 86 Z28 camaro......
also to make the LS1 into a 383 with the 4.00 stroke crankshaft do i need to bore out the motor any? haven't ever dealt with an ls1 motor before just the 4 bolt main thats in it right now....thanks again for all the help
MIKE
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Agreed and I would try and talk you into a 388 all bore for those AFR 225 heads.
A 4.125 bore head and a 4.125 bore block would make some Killer power.
Cost is only 500-700 bucks more and is a very nice setup.
As far as your origional question on the 383 you will need a 3.905 bore which is standard and a 4"crank. Very common build but not done very often these days due to the 408 making so much more power for the same price.
Go with the 225 heads for the all bore or stroker...
JZ'sTA....how do i go about making the 346 a 388 all bore? stroke? bore over? would the 225's work well with this setup? i'd actually be more interested in doing that being that i find a lot 383's around here, none being LS1 but i would like a 388 a bit more....
Tony M.
PS....By the way, just for clarification this will be the "traditional" LS 383 (3.905 bore and the longer 4" stroke).
I would wait for the results.
As far as the all bore 388 goes it is a 4.125 bore and a stock 3.622 stroke. You will need to resleave the motor.
The stock crank works great and is the strongest part of the motor and really there's no need to replace it unless your going bigger.
A 388 and a 427 are very similar the difference is the 427 uses a 4" crank. Again a very good combo.
Heads flow better on larger bores.
If a head flows say 310@600 on a 3.9 bore and is then flowed on a 4.125 bore it will flow better numbers. More then likely over 320 if setup correctly. It flows better from the start to the end.
This is a key factor in making power.
The nitrous will give you more then enough torque. Go All bore and I believe you will be happy you did.
This will be very close but not deadly accurate.
Were gonna use a .040 gasket and shoot for 11:1CR
We are also gonna use a flat top piston with -2cc V/R.
On a 383 you gonna need a 69cc head
On a 388 your gonna need a the same.
On a 427 you will need a 77cc head which I have never seen but I am sure can be done or you will need a -8cc piston with the 69 cc head I was using before.
