Oil pump install?
So I guess I need:
1) new ported LS6 oil pump and o-ring
2) water pump and 160 or 180 degree thermostat
3) new front cover gasket
4) new oil pressure sending unit
Is there anything else I should go ahead and change while I'm doing all this?
Just to note I'm also swapping in an LS6 intake, 28.8lb fuel injectors, and new fuel rails with the new oil sending unit.
They have an article on ls1howto, just in case you didn't see it.
http://www.ls1howto.com/index.php?article=4
Manny
I'd like to go ahead and do a cam swap, but I need to replace all of this just to see if the engine is trashed or not
I don't think I spun any bearings, and caught the low oil pressure in time, but I won't know till I do all of the above and start it back up. I'm draining the oil and taking the filter off to cut it open for inspection. Hopefully all will go well and all I'll need to do is mainly replace the oil pump.
So I guess I need:
People say they have a Z06 oil pump cause they do not know any better...the pumps are the same..you can get one ported and blue printed..but the GM pumps are all the same...gage or gauge you knew what I was saying or you would not have answered the post...this isn't english 101..
this is advanced hot rodding ...
..(sometimes) Last edited by eallanboggs; Jul 27, 2005 at 10:31 AM.
Like I said it may well be the sensor but I'm not going to risk even cranking it with a manual pressure guage to see if it's the sensor. The pump is a known problem so I'm replacing it and the sensor to rule out both.
30 min no oil. I find that hard to believe. Especially since people have spun bearings on here from running it 5 minutes.
