What causes the #7 to go first?
Old Jul 24, 2005 | 10:26 PM
Phil99vette's Avatar
7 Second Club
Default What causes the #7 to go first?
Topic says it all, what causes the #7 cylinder to go first on a F/I car?
Phil
Old Jul 24, 2005 | 10:29 PM
ninobrn99's Avatar
thats funny, cause thats the cylinder that went on Ed Blown Vert's ride. he's got a s/c and nitrous.
Old Jul 24, 2005 | 10:39 PM
7 Second Club
I have a customers car here that lost #7 on a stock 346 + maggie.
Phil
Old Jul 24, 2005 | 10:41 PM
ninobrn99's Avatar
he too was running the stock bottom end. chipped off about 1" of the piston and the cylinder wall and sleeve were cracked.
Old Jul 24, 2005 | 10:44 PM
liftin'em on nittos's Avatar
my motor broke #s 5 & 7, between about 3" around and 1/4" deep between the top and bottom rings...on both pistons. it was a NA SI car though, just lots of RPM and apparently not enough fuel.
Old Jul 24, 2005 | 11:19 PM
99ssleeper's Avatar
#7 and #8 tend to run the leanest.
Old Jul 24, 2005 | 11:24 PM
Grimes's Avatar
yup - end of the line on the intake manifold, and they probably get force fed more air! It would be interesting to see individual o2 readings on all 8 cylinders on an engine dyno.
Old Jul 24, 2005 | 11:54 PM
hopefully with my new sheet metal manifold and direct port setup i will have the tunability to keep things even all the way around. not to mention the motor will be tuned initially on the engine dyno so that helps.
Old Jul 25, 2005 | 12:35 AM
Jason99T/A's Avatar
I can shift faster than you.
I broke #5 and #7 naturally aspirated... 12:0:1 compression, stock pistons, lots of timing, summer heat, and pump gas.... BOOOOOOM! Detonation is not a pretty thing.....
Attached Thumbnails What causes the #7 to go first?-cracked_piston1.jpg   What causes the #7 to go first?-cracked_piston2.jpg
