Flycutting affecting Compression Ratio?
Old Jul 25, 2005 | 08:51 PM
Mazzenger's Avatar
Default Flycutting affecting Compression Ratio?
How much would flycutting pistons 40-70 thousanths
drop the compression ratio?
Old Jul 25, 2005 | 09:18 PM
Adrenaline_Z's Avatar
Depends on the volume of the relief.
Maybe 1-2 c.c. for the fly cuts...drops about 0.2:1 SCR
Old Jul 25, 2005 | 10:18 PM
JZ'sTA's Avatar
Agreed, the flycut dosen't hurt much but will change compression a bit.
Old Jul 25, 2005 | 10:26 PM
ArKay99's Avatar
I looked at the reliefs on the Diamond flat tops. They are ~.150" and ~2.375" diameter. Maybe someone can confirm this. They are 2cc reliefs. They must be ~1/4 the volume of the Diamonds if you are cutting 40-70 thousandths. So I would say somewhere between .5 and 1.0cc, closer to .5cc.
