lifter death AGAIN
Old Jul 27, 2005 | 07:07 AM
MadMike's Avatar
Default lifter death AGAIN
Help!, this is the second time the same exact lifter has broken. Head is off and cam is out, lifter is flattened. What would cause this same exact lifter to collapse every 3 months ??? doesnt look like a spun cam bearing.. any input is appreciated!
Old Jul 27, 2005 | 08:43 AM
crainholio's Avatar
I'd mic the lifter bores and look for variation...potentially that particular bore is smaller diameter than the rest, causing the lifter to drag.
I'd also pull the associated valvespring and a few others to have them pressure tested...potentially that spring is out of spec.
Old Jul 27, 2005 | 01:43 PM
9T9BlueTA's Avatar
Does your lifter look like this?
Old Jul 27, 2005 | 01:45 PM
PREDATOR-Z's Avatar
Is that a "Flat Roller Tappet ?" LOL
Old Jul 27, 2005 | 03:34 PM
robertbartsch's Avatar
Did you check the cam - this must be ruffed-up by now? Is this a high lift cam? How about the rest of the valve train components like the pushrod, rocker, spring, valve, etc?
Is this a stock lifter; I'm running a Comp racing lifter with a mild cam and no problems...
Old Jul 27, 2005 | 03:37 PM
9T9BlueTA's Avatar
shhhh custom hybrid technology
Old Jul 27, 2005 | 04:24 PM
MadMike's Avatar
Hey guys thnx for the responses so far, its a fms f4 cam, its nothing huge. they are all stock lifters, but im just curious as to why its that same damn one again.. there has to be something else wrong.and yes thats exactly what the past 2 lifters have looked like lol. If anything i want to atleast put another one back in cause i have limited time left before i have to put it back in the garage for winter again... i've already gone a month without it . The first lifter died with stock cam and 46k on the clock.. when i swapped to the fms f4 cam i upgraded to hardened rods, comp 918's and titanium retainers. I don't know what to do the car is apart. it took like 3 months to destroy this last lifter... if i put another one in for ha ha's just to ride out the rest of the season then maybe in teh winter i take the engine out. the lobe on the cam is Fawked. so i need another cam.. im looking at the fms f14 and while the heads are off i was thinking of doing some grinding. any suggestions ? or should i just put it in the garage and stick it out? mabye get aftermarket rockers?? thanks guys !!
Old Jul 27, 2005 | 04:33 PM
9T9BlueTA's Avatar
Unfortunately after the 3rd time this happened to me it was decided that is was a block issue or oiling issue (due to block). Either way I just decided to get an LS6 block with forged internals and never looked back. It was starting to get expensive replacing cams all the time .
Good luck in your hunt.
Old Jul 27, 2005 | 10:51 PM
LS1 Swapper's Avatar
Possible that the lifter is rotating in its bore, I'd look at the plastic(?) guide.
Old Jul 27, 2005 | 11:05 PM
StevieZ's Avatar
I would also say lifter bore.
Old Jul 27, 2005 | 11:31 PM
1QuickT-A's Avatar
I'm gonna have to go with the lifter bore.. Its very possible that the lifter is rotating in the bore. This same exact thing just happened to a friend of mine but it was a ford engine. His lifter looked exactly like that and it was because the spider tray broke and the lifter turned in the bore.
Old Jul 28, 2005 | 10:40 AM
MadMike's Avatar
thnks for the help guys, im workin on figuring it out, I have to slide the cam back in before i can see if the tray is broken. im at work right now so we'll see, .. im looking at the lifter now and it looks like where it goes into the tray is worn down on the sides, and beat up on the top (pushrod side).. is this normal ?
Old Jul 28, 2005 | 12:54 PM
MadMike's Avatar
you guys are awesome!! thats exactly the problem ,, i had a few min at lunch to check it out and the plastic tray is the problem , thanks for all your help .. parts are ordered!, all i need now is a cam,im looking at fms cam's again but last time it took 4 weeks to get to me so i want the most aggressive cam i can get that will work with stock heads.. any good suggestions ?
Old Jul 28, 2005 | 02:24 PM
distortion_69's Avatar
I got another F4 cam for sale for $300+ shipping brand new in the box if you decide to go back to what you had. No waiting.
Peace,
Josh
