Bitten the bullet
Old Jul 27, 2005 | 03:11 PM
v8robert's Avatar
Default Bitten the bullet
Thanks for all your advice lads over the last few weeks, this site is tremendous
Bitten the bullet and gone for the AFR 205 heads and FMS 13 112 camshaft for my LS6 in my gd cobra replica. Should be a blast
Will post my dyno graph and numbers when installed.
Need to sell my LS6 heads and camshaft in the UK. Any suggestions about pricing ?
Cheers
Rob (UK)
Old Jul 28, 2005 | 01:21 PM
v8robert's Avatar
Come on, give us a clue
Old Jul 28, 2005 | 04:24 PM
GuitsBoy's Avatar
Well, in the states a set of used ls6 heads and an ls6 cam would probably go for around $800.
Old Jul 28, 2005 | 09:58 PM
1QuickT-A's Avatar
Robert, you are a smart man! Can't go wrong with the AFR's or the F13!
Old Jul 29, 2005 | 05:05 AM
v8robert's Avatar
I'll tell you if i'm a smart man after Spa ! Bit worried about that much power going through the back wheels in a car that weighs 950kg. Going to get some sticky rubber like thats going to make it safe !!
800 bucks then for used LS6 head and cam ?
Cheers
Rob
Old Jul 29, 2005 | 07:41 AM
GuitsBoy's Avatar
800 bucks then for used LS6 head and cam ?[/QUOTE]
Well, figure used ls6 hears normally go for between 600 and 800 depending on condition. And the used ls6 cam is probably only good for 100-150. put em togather and depending on how many miles are on em, you might see a little less or a little more.
