valve springs
Now, you said one of your springs "snapped" ? May I ask what kind of spring was it ?
Are you sure your valve didn't drop and bend ?
Maybe for extra peace of mind you wanna consider, Patriot, Crane, or PRC duals....
www.ls1howto.com
see cam swap writeup for f-body and yella-terra rockers install...
As far as rockers, tighten them down to 22 BUT use some locktide. They won't lossen up this way
Usually a loud valvetrain is an indication of too little peload which is determined by the length of your pushrods. Check your lifter preload and get the right p-rod, that should quiet things down a bit. (IMO 7.425 p-rod from COMP CAM will do it)
How many times do people have to tell you this before you realize that more is not better?
If it was not making noise before, make sure the pushrod is in correctly(can't see how it wouldn't be), the rocker arm is aligned correctly, and that it is torqued down to 22ft/lbs.
If its still making a ton of noise, then you might want to look into a bent valve. When you snapped the spring it could have lightly kissed the piston and bent the valve. That would definitely cause some noise in there.
Please.......22ft/lbs. You don't set lash on a stock motor either.
