Is this the right Crank Bolt? (Pic)
Old Jul 28, 2005 | 04:23 PM
BigBlockChev572's Avatar
Default Is this the right Crank Bolt? (Pic)
OK, I got the stock bolt, then I went and bought another one longer in length, M16 2.0 thread pitch 130MM. I'm hoping I bought the right one that you all have been using.
Thanks, Philip S.
Old Jul 28, 2005 | 05:25 PM
Tally TransAm's Avatar
Old Jul 28, 2005 | 05:51 PM
My fault, I was having some difficulty with Photobucket so they were deleted. They're up now.
Philip S.
Old Jul 28, 2005 | 06:02 PM
looks good to me, just get a fat stack of washers to go over it
Old Jul 28, 2005 | 06:07 PM
Bear with me, I'm trying to think of the purpose washers would serve. I'm imagining a crank puller and the head of the bolt being pushed on as the pulley slides towards the puller. What's the purpsose of the washers?
Thanks,
Philip S.
Old Jul 28, 2005 | 06:31 PM
the washers are for reinstallation, which is the primary reason for the longer bolt.
the longer bolt lets you get more threads started when you are reinstalling the pulley which significant reduces the chance of cross threading or fubaring the crank threads. however the small head of the new bolt will go right through the pulley so you need large washers
basically i use like 2-3 large washers on the longer bolt to get the pulley on about 60-70% of the way, but then take the longer bolt out and use the old stock bolt on and finshed the installation normally
Old Jul 28, 2005 | 06:34 PM
OH OK! Thanks! I was having an anurism just thinking of the purpose for pulling the pulley off! Thanks, yes, I gotcha!
Philip S.
Old Jul 28, 2005 | 06:35 PM
T/A Medic's Avatar
if you dont use a washer over the head of ur new bolt u are going to scrape ur crank balancer and dig into it... also should distribute the load across more surface area of the crank pully... not sure if that makes a big deal...
line up the threads on each bolt... if they sit in there really nice it is the same bolt thread.
