help with harland sharp rocker preload
Old Jul 29, 2005 | 11:19 AM
biomedengny's Avatar
Default help with harland sharp rocker preload
are there shims avalible for the rocker stands for proper lifter preload.
and do people shim them or use as is??
thanks everyone
Old Jul 29, 2005 | 12:28 PM
PREDATOR-Z's Avatar
Lifter preload on HS (non adjustables) is determined by the length of your p-rods.
You only need shims if your geometry is not right.
