Which springs for F13??
Old Jul 29, 2005 | 03:50 PM
FUN LS1's Avatar
Default Which springs for F13??
I'm going to put in an F13, and wanted to know if the Comp 918's are good enough, or if I need dual springs? Which will last longer? The lift on the F13 is .595/.585, duration is 230/232. Since the F13 power band tops out at 6800, will I need to upgrade the lifters?
Old Jul 29, 2005 | 04:18 PM
1fastWS6's Avatar
I run the Comp 918's. They'll probably last 25-30k. Duals are better if you want to spend the money and may last longer. Lifters are fine stock.
Old Jul 29, 2005 | 04:27 PM
ninobrn99's Avatar
prc dual's
Old Jul 29, 2005 | 05:50 PM
Ru2n00n3er's Avatar
Allan recommended dual springs for me, so I'm going with the PRC duals.
Old Jul 29, 2005 | 05:52 PM
Shu's Avatar
Shu
Im running the PRC duals
Old Jul 29, 2005 | 05:55 PM
FUN LS1's Avatar
How do you like the Spec 3? I'm ready to replace my stock clutch
at 85K I have to baby it some now
Old Jul 29, 2005 | 05:56 PM
SideStep's Avatar
Lots of members here running that cam or close to it with 918s....
Old Jul 29, 2005 | 08:21 PM
slpss9723's Avatar
I figured he knows his ****
 Michael S. Palmer
Old Jul 29, 2005 | 08:47 PM
ss rally red's Avatar
Allen does know his **** no dought, but 918's will work no problem.
Old Jul 30, 2005 | 03:35 PM
f-bodman's Avatar
PRC duals here too.
Old Jul 30, 2005 | 03:50 PM
PunkNPonys's Avatar
I like the Manleys. I think they are a better quality then the PRCs IMO. You need to run duals dont chance the 918s. Goodluck.
Old Jul 30, 2005 | 04:21 PM
LS1FC3's Avatar
I plan on running the PRC duals as I am more than likely getting this cam along with stage 2.5 5.3 heads.
Old Jul 30, 2005 | 04:23 PM
BAD ASS TA WS6's Avatar
BMW ///M Nerd
I'm going to run COMP 921 Duals with my F14.
Just a little more money than the PRCs.
Old Jul 30, 2005 | 04:42 PM
Candy's Avatar
The 918's are working for some with no problems but we recommend that you use a dual spring with the F13, the PRC dual kit is actually cheaper than the 918's and retainers.
Old Jul 30, 2005 | 10:08 PM
FUN LS1's Avatar
Thanks to all. I think I 've decided on duals, hoping I'll get longer wear.
Old Jul 30, 2005 | 10:59 PM
slpss9723's Avatar
damn money bags!!!!!!j/k
Old Aug 1, 2005 | 10:12 AM
GuitsBoy's Avatar
Id personally run duals over 918, unless you really have a reason for running singles (want a lighter valvetrain) and know the risks.
I would say just get whatever gold kit you can get cheapest. Patriot, PRC, TEA...
Old Aug 1, 2005 | 10:27 AM
2000PewterZ28's Avatar
The manley springs are not polished.How can this be better quality?All of them are made of good material.The PRC springs are top quality for the price.
