36 lb Injectors big enough??
Will 36lb injectors support 430 rwhp? Am I cutting it too close?
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
edit- make that 89-90% auto-taped it tonight
The shop I got to locally works on high-end imports, but I don't have a lot of confidence in them when it comes to knowing the LS1, so I started taking it to Central Fbody in Baltimore for engine work. But that's too far for anything but the stuff I can't handle because of lack of tools and lift.
Will I need a new in-tank fuel pump to support the 36 lb injectors?
I'm at 445 rwhp and I've not had a problem with leaning at WOT. I guess a new pump couldn't hurt. Let me know if you want the tune/tables.
Good luck.
joel
What they usually forget to check or do is that if an injector is rated 28.8 at 58 psi; is their pressure actually 58 psi at the rail?
Stock 01/02 28.8 will handle ~ 450 rwhp on maintained 58 psi pressure and 30 lbs SVO (actually 34.54 at 58 psi) will handle 550 rwhp.
So before you gop crazy on injectors, get an adjustable FPR at the rail and adjust it to maintain good psi at wot. You'll be ammazed how much the pressure drops with our shity regulators at the back.
Good to know, I guess I'll be extra safe than
