ARP main studs guys inside please
Old Aug 1, 2005 | 05:59 PM
camarogod98's Avatar
Default ARP main studs guys inside please
I bought a set of main studs from LS1speed.com and when i opened it i noticed something funny. There are 30 washers, 20 black nuts, 10 silver nuts, 10 long studs w/ long threads, 10 short studs w/short threads. Shouldnt there be 10 more studs to go with the other 10 nuts and washers?
what am i missing.
Can anyone tell me if im right?
APR part # 234-5608
Old Aug 1, 2005 | 06:21 PM
ROCNDAV's Avatar
maybe those are for the windage tray? the washer as a spacer and teh nut to hold the windage tray?
Old Aug 1, 2005 | 06:25 PM
xssive's Avatar
Yup those are the tindage tray nuts/washers.
Old Aug 1, 2005 | 06:28 PM
Default thanks
thanks for the info guys......It freaked me out paying 175 bucks for some stupid studs and when i saw 30 nuts/washers and only 20 studs i freaked!
Old Aug 1, 2005 | 06:48 PM
ROCNDAV's Avatar
Did you have to drill out and tap the holes?
I now feel bad for not groing ARP with the mains. At the time, when I sent it off to the machine shop, I only thought I was going to build up a stock LS1, then I decided to go the stroker route while it was there.
I ended up staying with the stock hardware as they line bored it and honded with with those torqued and head that I could change the geometry if I used those afterwards.
Since then just about everything has been ARP (even the camshaft bolts and cam cover botls lol). just wondering if its to late to do myself. the engine is still on the stand.
D
Old Aug 1, 2005 | 07:38 PM
1point3liter's Avatar
i had to open up some some of the holes in my windage tray. Otherwise no other modifications were needed.
Old Aug 1, 2005 | 08:37 PM
ROCNDAV's Avatar
so the studs screwed straight into the block?
Hmmm, maybe it isn't too late. I've had to modify the windage tray already anyways
D
