Removing heads, idea/??
Old Aug 1, 2005 | 10:11 PM
conan's Avatar
Default Removing heads, idea/??
I'm removing my heads to replace arp bolts with arp studs. If I were to take out the brass plugs on the side's of the block draining the coolant along with removing the water pump, would this eliminate most of the coolant mess that comes with pulling the heads? Has any one tried this before?
Old Aug 1, 2005 | 10:54 PM
HavATampa's Avatar
I took both plugs out of the block before I removed the head bolts and had no water to clean up from the bolt holes or the cylinders. It's worth the extra time IMO. Check out this link for wrench sizes and pics:
https://ls1tech.com/forums/generation-iii-internal-engine/335413-afr-s-fast-90-nw-90tb-poly-mounts-fast-rails-finally-done.html
Old Aug 1, 2005 | 11:16 PM
conan's Avatar
Cool thanks. When I was swaping parts from my original moter to my SB I thought about doing this guess I get to find out. I have a tube Kmember too, so geting to them is verry easy.
