Why not just go 427?
Steve
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
I was going to use an LQ4 block.
you can do a 421ci iron block with a standard ironblock bored 4.030(.030 over) and use a 4.125" crank
4.030x4.030x.7854x4.125x8=421ci
If you go with a Darton MID and go with an offset ground stock crank (3.71" or so and it's plenty strong) you can do 397 or 403 for about the same price as an iron block with a Callies or Lunati stroke. The difference is that it's undersquare, so it'll rev much better, and the 4.125 or 4.155" bore will allow more airflow at high rpms. Not to mention it's lighter than the iron block and makes similar torque and horsepower numbers with less displacement and generally less radical cams.
Thanks
This is going in a z06 and I have had people tell me not to do an iron block. I cant imagine 75lbs. making a huge difference. I meen these guys that add chargers are putting 50-60lbs on there front end as well. So I figure I might as well do it with cubes.
Your thoughts.
Thanks
Your thoughts.
a 4.030 bore and a 4" stroke would be a 408ci
a 4.060 bore and a 4" stroke would be a 414ci, some of the iron blocks can be bored to a 4.060 bore, just need to sonic check the block to be sure.
