Who has or can ind. test coil bind on 918s?
and pressures at different installed heights as well? Comp lists coil bind at 1.085 but Ive seen them at 1.135. Need to know for certain with a valvetrain setup Im going to try
itchygomey98 did before. He was saying it was insanely high, around .750" of lift if i remember correctly. They are rated for .600" but you can run more lift than that as when they initially hit the market they were rated to .610 or .615 but after the 987's came out they down rated them (probably to sell more sets of the duals).
Nate
Nate
Send an email to bret bauer aka "sstrokerace" i know he uses that spring quite a bit
bret@bauer-racing.com
