GT2-3 with LS6 springs question
Old Aug 3, 2005 | 11:33 PM
Redneck Z's Avatar
LS6 springs should be fine. They used to be rated at .600 lift and have been revised, but many run the gt2-3 with the LS6 springs without problems.
Old Aug 4, 2005 | 12:39 AM
Dan_the_C5_Man's Avatar
I've spoken to several techs at LPE, and they ALL say the same thing. LS6 springs.. Now, keep in mind the 01 MY springs are NOT the same as the 02 and above springs..
That said, they also re-use the stock push rods all day long, which I know is "wrong". The base circle of that cam is not close to the stock LS1 cam. Oh well.
Old Aug 4, 2005 | 08:38 AM
roccox's Avatar
I know a lot of people complained about failed LS6 springs in their Z06's. Does anyone know if that was limited to 2001, or if it happened with the 2002+ LS6 design.
Old Aug 4, 2005 | 04:34 PM
redtail2426's Avatar
oh and by the way if you use the gt2-3 then use 7.425 pushrods.stock length are to short,lpe says you can use them and a lot of people do but 7.425's are much closer to maintaining stock preload.I measured the lobe radius at a machine shop and they are .735".the stock lobe radius is .776".that means you need a pushrod that is .041" longer then stock.the stock pushrod is about 7.395" on average.(i measured 6 stock pushrods and this was average.)7.395+ the .041" is 7.436".The closest you can get is comp 7.425" which will still be about .010" shorter then stock but close enough.Stock 7.4" will be about .036-.040 to short which is to much in my opinion.(this formula can only be used on a stock engine with no milling).
Old Aug 4, 2005 | 05:41 PM
Rob's Avatar
Rob
Originally Posted by goober35
Guess LPE needs to get a brain scan. Good way to trash a good motor.
Whatever. Facts are facts. The springs work with that cam. I have over 7K miles on mine so far without any problems.
Stock pushrods too
Why reinvent the wheel. Its proven and it works. They wouldn't warranty the stuff if it didn't work.
Old Dec 17, 2005 | 06:50 PM
Fast GTO's Avatar
I talked to LPE about this as well and even mentioned everyones concerns. They told me flat out that I will have NO problems running stock pushrods and ls6 springs with this cam.
If I have an engine failure due to either of those components you can bet I will be sending them my repair bill, but I am 100% certain that I won't have any problems.
Old Dec 18, 2005 | 12:08 PM
PREDATOR-Z's Avatar
You can run LS6 02+ springs with no problems, BUT I would change the p-rods to aftermarket hardened ones.
The stockers WILL flex and probably bend. That I''m 101% sure.
Old Dec 18, 2005 | 05:11 PM
Rob's Avatar
Rob
You are probably right. I'm at 10K on the springs and 11K on the pushrods. No problems so far...knock on wood
Old Dec 19, 2005 | 07:39 AM
roccox's Avatar
I actually did chicken out on this cam. I am going with the Vinci 210/218 .551 116 cam. I am sure the GT2-3 would be fine, but being ultra conservative, I would rather the .551 lift as opposed to the .580 lift on LS6 springs.
Old Dec 19, 2005 | 02:04 PM
wildta's Avatar
I ordered this cam on a group purchase a couple of years ago, I asked about the springs and Ed sent me some 918's with blue stripe.
Old Dec 22, 2005 | 06:13 PM
Fast GTO's Avatar
Jeff at LPE just told me the stock pushrods are fine, he even read this thread.
Old Dec 23, 2005 | 08:36 AM
  #32
Mehfoud's Avatar
I have run the GT2-3 Cam for about 25,000 miles with 918's. I have no problems what so ever and I run hardened 7.4 push-rods. I might sell the cam soon though...
