What lifters should I use?
LS1Tech Sponsor
Posts: 538 the Comp pro-mag lifters(R)(875's) are only supposed to have .002"-.004" preload..any more than that could result in the retaining clip getting popped out of the lifter and causing lifter failure...so...they only need like 1/16th of a turn past zero lash..so..that being said..in no way,shape,form,or fashion can you just torque them to 22ft/lbs...now..on the OEM style(850's)..they are for standard recommended preload of .030"..just like anyother hydraulic lifter..so torque to spec will be just fine on those
LS1Tech Sponsor
Posts: 538 ok..calm down. Yet again we need to discuss this. DO NOT confuse lash with preload. This is apples and oranges, we are talking about two completely different things. Lash is slack in the system, preload is just that..pre..loading the system. The pro mag lifters require .002"-.004" preload HOT..not cold. I would probably put .008"-.010" preload when cold. Zamboxl..you have a Pm.
2 kinds of LSx rockers
A- adjustable
B- non adjustable (non adjustables are trqd to 22ftlbs), only way to adjust preload is by custom push rods or shimming the stands. But this is in NO way accurate. With a big cam, you want to be accurate so (adjustables are the way to go)
I have a set of Comp R's in listed in the classifieds. They are brand new (just been soaked prior to assembly). I swapped out to the Comp 850-16 lifters during the build because I didn't want to spring for adjustable rockers (for the reasons Predator Z noted above). If you want them, I'll do $175 shipped.
Thanks,
Ryan
P.S. Gomer can vouch for me, I just sold him a new FM13 cam.
You can Get them through Nate @ Nasty performance -------->
Have you check the preload on several rockers to ensure it is correct?
