Best Cali cam for spray
SSU's Drunk Typing Whore
I am looking to get a cam soon, I am also planning on spraying. What would the best cam be for a 100 shot? I know that the 224 cam would do fine with a 100 shot, but I am curious to know what cam you guys would choose if you lived in Cali and planned to spray, also while being emissions safe. Thanks guys!
110 wet or a 100 dry?
224 on 114 with a lean emission tune and the N2O system with a timing box to modify your tune under nitrous and with MAFT to richen.
That way you are legal with cam N/A and under juice you are optimized.
MAFT allows you to richen via MAF and can be modified by simple dialing of buttons (2 min) and the Timing box reduces your timing under the shot (preset).
Wet Shot......sorry bout that. Thanks for help as well. I was thinking of going with the 224 but I just wanted to know if there were better cams out there for a 100 shot. I have read some posts saying that its an ok cam for that and its not going to make much of difference since the shot is so low.
It will not make any difference.
I shoot 200 dry on a 224/220 .581/.581 116lsa+0. (Stealth II).
Completely emission compliant and will astonish you how it handles the nitrous.
I'm 10.93 with a 150 shot, on an A4. I'm adding a set of PRC 2.5/5.3L heads and hoping 10.5x>10.6x after that.
