just changed pluggs . . . Car runnin bad!
Old 08-07-2005, 08:59 AM
PREDATOR-Z's Avatar
Originally Posted by NXZ28
I had to take the coil packs off. Use a 3/8" drive ratchet, short extension, and a u-joint. Be careful not to snap the top of the spark plug off.
That will work too
Old 08-07-2005, 10:14 AM
TOZ
TOZ's Avatar
take the #8 from the bottom of the car, it is so much easier.
Old 08-07-2005, 11:50 PM
vodas00ss's Avatar
i dont think its the best idea to be spraying your MAF with carb cleaner.
Old 08-08-2005, 08:01 AM
GuitsBoy's Avatar
I use a gear wrench on the outside of the spark plug socket from the top with the coil packs off.
Old 08-08-2005, 09:26 AM
slt200mph's Avatar
Use flexhead ratchet and a 3 inch extention and a one inch extention..that combo of tools will change all of them..changing # 8 from under the car works best..I have all the smog stuff off my car and I can change plugs in 25 minutes with out taking off the coil packs... make sure you feel the two clicks on the coil end and the single click on the plug end of the wires when you put them back on..
Old 08-08-2005, 10:11 AM
andy1h2004's Avatar
thanks all again for the advice
Old 08-08-2005, 10:13 AM
andy1h2004's Avatar
has anyone ever cleaned they're injectors if so how?
Old 08-08-2005, 10:15 AM
GuitsBoy's Avatar
Bottle of techron in the tank works for most of us. Not sure if you want to remove them and have them sonically cleaned...
Old 08-08-2005, 10:16 AM
andy1h2004's Avatar
cheata cams, I think this is what it's called I heard u can recieve about 20 to30 horses rear wheel , is this true anyone, oh if anyone has this how is the gas mileage and how much did it run you?
Old 08-08-2005, 10:56 AM
andy1h2004's Avatar
why does are a higher pound injector better, do they give out more horses or somthing. . .
Old 08-08-2005, 11:01 AM
GuitsBoy's Avatar
Well, just about all engine modification achieve one goal, they cram more oxygen into the cylinder. As you cram more air into the cylinders, then injectors need to flow more fuel to keep the mixture correct. If you keep on modding or so some serious mods like forced induction or nitrous, youll have too much air for the stock injectors to keep up with. Swapping injectors will not gain you anything, but once you get into heavy duty modifications, bigger injectors may be required.
Old 08-08-2005, 11:09 AM
  #32
gollum's Avatar
Bad O2 sensors will make your car run rich. Use AC Delco brand sensors and sparkplugs 41-974
Old 08-08-2005, 11:12 AM
  #33
andy1h2004's Avatar
thanks, I went back to the ac delco, and I do have 1 bad os sensor, I will replace that, oh and also thanks GUITSBOY for the lesson on the injectors just was wondering. also does anyone use the tr-55 plugs; I've been hearing alot about those and was curious. . . thanks all for the patients trying to learn all this stuff. . .
Old 08-08-2005, 12:15 PM
  #34
slt200mph's Avatar
TR 55 at Advance Auto Parts $1.68...lots of guys use them..
Old 08-08-2005, 12:21 PM
  #35
andy1h2004's Avatar
r they any getter than say ac delco
Old 08-08-2005, 04:33 PM
  #36
gollum's Avatar
AC's are platinum, 55's are copper core. Doesn't platinum last longer?
Old 08-08-2005, 05:22 PM
  #37
slt200mph's Avatar
Look at some plat plugs that have been run for a while lots of time the plat is off the plug..for $1.68 a piece you can't go wrong on a TR 55 NKG ..If your a serious hot rodder you going to look at your plugs from time to time ..they tell ya whats going on in the engine..
