LS6 Cam
Make some calls and look at some websites. You can get away with just switching out the cam, but new springs and retainers will give you some insurance and lighten up the valvetrain and you might as well do pushrods as well. You'll find that there are better cam options out there once you do some research. You don't have to go big to make big power either.
Timing chain and oil pump if your car has over 50,000 on it.
You want springs, timing chain, push rods at the very least. Will not 100% necessary, you will have to remove them for teh cam anyway...
Dave
What you need:
-LS6 02>up cam
-LS6 02> up springs
-7.425 push rods (for exact proper geometry), you'll see replies (I use stock ones, but then your lifter preload will be lighter with possible valvetrain noise)
-1 cam swap gasket kit (front cover gasket, water pump gaskets, front cover seal, crank bolt)
-1 LS2 timing chain with 2/3 oil pick up tube O ring (spares if you bust one)
+ tools.
Install instructions on: http//www.ls1howto.com
Erich
Erich
The cam will pull very hard after 3500 RPM - not a bad cam. Remember without the header but intake and cam, it should be like an LS6 - 400 at the crank. With the headers maybe 20 more.
Bill
Erich
Do you care to explain how they don't have planning, and you do? I'm curious based on what you have said so far.
This is just my two cents - with LS6 cam, you don't have to worry about changing valve springs every 30K miles or so. It is designed by GM to go the life of the car. That is not saying that the springs will not fail. The LS6 spring are only for .571 lift max. To tell the turth, my car is only a once awhile weekend warrior but I am not interesting in taking it a part - it is not a real fun car to work on and some case it is a real pain the a$$.
Bill
Bill
The GT2-3 is a pretty good cam as well, but I really don't think it is worth the extra money for the gains vs. the LS6 cam, well not in my experience. I"ve got a friend that has that cam with LPE heads..tuned and it doesn't trap any higher than mine with an LS6 cam, untuned.. his car loves the juice though with that LSA.
If the LS6 cam is still what you want, go for it.
