Path of the Oil...
Old Aug 5, 2005 | 02:20 PM
BlackWS6LS1's Avatar
Default Path of the Oil...
Can someone give me the step of the oil, Pickup tube, oil pump... Then where does it go? I really wanna know where the filter is in the process? Thanks again.
Tom
Old Aug 5, 2005 | 02:21 PM
oange ss's Avatar
filter is the last step of the process
Old Aug 5, 2005 | 02:41 PM
Grimes's Avatar
filter isn't the last step....
pickup, pump, main galley towards oil filter, filter, up rear of block, lifter galley, mains and top end
Old Aug 5, 2005 | 04:20 PM
WOW good info!!
Old Aug 6, 2005 | 07:41 AM
Lasershop's Avatar
You can see the casting of the main oil feed on the left side of the block. From the pump it goes straight back to the filter. The filter is first base. Mains, cam and lifter oil galleys branch off from there.
Old Aug 6, 2005 | 08:13 AM
PREDATOR-Z's Avatar
Yeap, filter first. only makes sence to have a steady supply and adequate pressure while going through it.
Old Aug 6, 2005 | 10:40 AM
Ok I thought GM was dumb, I/m so glad someone chimmed in diffent than above. Thanks for the info.
Old Aug 6, 2005 | 10:44 AM
y2khawk's Avatar
It's actually
pickup, pump, filter, factory oil cooler(if equipt), lifter galley, cam bearings, mains bearings, rod bearings.
it's all a series path. Each cam bearing/main pair gets feed from the lifter galley.
rockers and springs get fed from the lifters.
Old Aug 6, 2005 | 05:57 PM
Grimes's Avatar
you're a hard one to please hawk!
from the book "chevy ls1/ls6 v-8s" by will handzel. a pic IS worth a 1000 words, lol .....(and sorry for the pic, my scanner is broken )
