SLP Doble Roller Chain HELP
Old Aug 6, 2005 | 08:47 PM
TOZ's Avatar
TOZ
Exclamation SLP Doble Roller Chain HELP
I installed the doble roller chain from SLP, Everything was perfect clearence was good, but when I started to put the pulley on and started to tight it up,( I forgot to put the car in 4th gear to stop the pulley from turning), so when I turned the pulley and turned the motor I heard the sound of the chain rubbing something when the motor was turning, It sounded like the chain rubbing with something. I took the pulley off and opened the timing cover and there was no mark of rubing it. Could it be the oil pump rubbing it ? I did put the spacer on it.
I also tryed turning the engine without the pulley and with out the timing cover and it didn`t make that noise. So I don`t think is the oil pump touching it, there some space in between them. I thinking if the pulley is pushing something in there to make this happen .
PLEASE HELL !!!!!
Old Aug 7, 2005 | 12:13 AM
nostyta's Avatar
Is it the stock pulley or after market, if it's an after market is it designed to fit the double roller timing chain?
Old Aug 7, 2005 | 01:08 AM
TOZ's Avatar
TOZ
its a stock pulley
Old Aug 7, 2005 | 03:13 AM
nostyta's Avatar
If it's the stock pully there shouldn't be any fitment problems, when I had mine installed it fit perfectly. Anyway good luck finding the problem.
Old Aug 7, 2005 | 03:58 AM
eallanboggs's Avatar
Is the cam chain/oil pump sprocket seated fully HOME against the boss on the crankshaft?
Old Aug 7, 2005 | 09:48 AM
TOZ's Avatar
TOZ
Yes they are both seated perfectly. I just re did everything without any RTV for testing and everything went smotth, today I will recheck and pull everything out again to RTV everything and hopefully nothing will touch
Old Aug 7, 2005 | 01:06 PM
tomulrich's Avatar
What is rubbing is the boss around the seal on the timing cover. In the instructions it tells you you may need to clearance the cover. I had the same thing happen......you probably only need to take off .040 for clearance.
It has nothing to do with your balancer.
Tom Ulrich
Old Aug 7, 2005 | 02:51 PM
PREDATOR-Z's Avatar
Tom Ulrich
Good info.
Old Aug 7, 2005 | 09:54 PM
TOZ's Avatar
TOZ
ok, put everything back together, and rubbing stoped. May be there was something that didn`t go in right the first time. Didn`t have to do any griding what so ever. Lets just hope everything goes ok when I start the car.
Old Aug 8, 2005 | 12:02 AM
Uthinkso's Avatar
I have had a incidents where there is a rubbing problem with those timing sets.
The area around the seal had be slightly clearanced and situation solved.
