what does head castings mean?
Old 08-08-2005, 10:35 PM
Michael Ozorowsky's Avatar
Default what does head castings mean?
just curious what the casting number for heads mean? Thanks.
Old 08-08-2005, 10:43 PM
Grimes's Avatar
it's just a random number - each head casting is a little different from the others. as gm finds new stuff out, they make improvements as the years go by. some castings flow better, some worse. simple as that!
Old 08-08-2005, 11:24 PM
So if heads are ported, head casting #'s are worthless, right?
Old 08-08-2005, 11:34 PM
CharlieLed's Avatar
No, not worthless, they still tell you where the head started. A ported 243 LS6 head is going to be a lot different that a 241 LS1 head with the same work done on it...
Old 08-09-2005, 12:03 AM
how so?
Old 08-10-2005, 09:18 AM
777's Avatar
Different port designs and chamber's. 243's start out with a higher compression ratio as well. They are basically a different design that you cannot create by just porting them.
