Cam suggestions please
Old Aug 13, 2005 | 08:58 AM
blkZ28spt's Avatar
I agree. Earlier I said to check out the MS3 or G5X3, but the X4 is probably an option as well as a larger Futral grind. F14 or F15 even.
I have no problems daily driving my MS3. Just a little stumble here and there.
Old Aug 13, 2005 | 09:07 AM
scottyballs's Avatar
for a cam like the trex The ideal setup with a A4 would be a 4000+ stall on 4.10's or 3.73's but Im sure your setup will work, but probly not as efficient.. I would do like predator-z said fm13 or g5x3 there still pretty large cams...
Old Aug 13, 2005 | 02:32 PM
General Jack's Avatar
Originally Posted by 35thls1ss19
and do not want to have to red line way up top (6700rpm)
This right here rules out the TRex, I think you have to shift at 7,000 to get everything out of it... not to mention adding gears.
I daily drive a moderate sized cam (see sig) and probably wouldn't go very much bigger, F13 or Torquer II at most, and I don't mind a little bit of unruliness. However, the TRex is way bigger and just flat out nasty . Talk to the guys at thunder, they're great. I think they'd recommend one of their smaller cams for you.
Old Aug 13, 2005 | 03:01 PM
Reject's Avatar
so the F14 would be the biggest street cam you could live with? with a 3500 stall and some gears in the back? correct? along with the tune and stuff, that would be able to break into the 400 hp mark right?
Old Aug 13, 2005 | 03:13 PM
blkZ28spt's Avatar
My setup, MS3 and 4000 stall converter is about as high as I would go. You can substitute a G5X3/4 or something similer for the MS3 if you like.
Don't count on hitting 400rwhp cam only through an auto. It happens, but more often than not it doesn't.
Old Aug 13, 2005 | 03:18 PM
Reject's Avatar
embarrased but what sites have the MS3 or G5X3/4 i jwas reading the other cam post and you mentioned this same cams and havnt been able to rfind the sites, so are those two cams you mentioned the same as the F14? and maybe with alil tunning skills MAYBE 399.9 hp?
Old Aug 13, 2005 | 03:21 PM
Reject's Avatar
HOLY ***** thats a big *** lift on that MS3, rattle your teeth...maybe i could have more power since i have a 2000? all those suspension mods really show in the 60' times!
blkZ28spt's Avatar
MS3 is sold by TSP www.texas-speed.com
G5 series cams can be found at www.lgmotorsports.com.
Search button on this site will tell you more than those websites, though.
Don't count on or worry about 400 rwhp through an auto. Dyno numbers alone mean next to nothing. I have 385 rwhp and ran 11.92 in June on stock suspension with no weight reduction mods. *none that cost money, only minor things like rear seats, FSB and spare tire/jack.*
The MS3 and G5X4 are both larger than the F14.
Old Aug 13, 2005 | 03:28 PM
Reject's Avatar
yeah i need some weight reduction on me then!! how streetable/liveable are you with the MS3?
Old Aug 13, 2005 | 03:34 PM
shaulinmathvader's Avatar
Hey 6spdpewterz what kind of problems does your friend(BUCK) have
Old Aug 13, 2005 | 07:17 PM
35thls1ss19's Avatar
So out of these cams which would be best with my m6 and a 150 shot? Best meanin most hp and decint driveablity.... the car will only be drivin 2-3 times a week
Old Aug 13, 2005 | 08:51 PM
  #32
blkZ28spt's Avatar
Depends on what you are willing to deal with and what decent drivability means to YOU.
Old Aug 17, 2005 | 12:43 AM
  #33
slowredz's Avatar
Are those your current times? Seems way slow for the power and setup you have. Street tires maybe?
Old Aug 17, 2005 | 10:46 AM
  #34
blkZ28spt's Avatar
11.92 in a cam-only near full weight F-body with stock suspension on street tires in June? I wish.
Yes those times are current. Ran on ET streets, 60' was 1.64. I don't know what you are going by, but 11.9 isn't exactly "way slow" for a cam only daily driver F-body. To put in perspective I ran 12.6 with stall, lid, CAI, longtubes, duals, and ET streets (untuned). Then I ran 12.21 with the cam/tune, and finally the 11.92 with LS6 intake, SLP UD pulley and fully functional transmission.
Old Aug 17, 2005 | 06:49 PM
  #35
Ru2n00n3er's Avatar
You have to remember that it's Nate driving.
Oh wait, that's me. I'm the one with the full bolt-on car that runs high 13's.
