Valve Spring Swap
Old Aug 12, 2005 | 10:57 AM
arctic2kss's Avatar
Default Valve Spring Swap
Any suggestions on what valve spring compression tool I should use? Does the one from Autozone/O'Reilly's work well enough?
Old Aug 12, 2005 | 11:06 AM
777's Avatar
777
I wouldn't use that one if I were you. There are several compressors out there. The Larry tool, Someone else tool, along with a few sponsors. I'd go with the one from (I forgot let me find it )
:edit: I think it's the crane one, but I'm not sure.
Old Aug 12, 2005 | 11:07 AM
Ru2n00n3er's Avatar
NO, coming from a friend of mine who tried using it. It took him 2 hours to do his first cylinder, then he decided to buy a Crane Cams tool and after that it took him 15 minutes to do each cylinder. The crane cams tools is more expensive but will save you a LOT of time.
Old Aug 12, 2005 | 11:55 AM
jmm98LS1's Avatar
I used a version of the larry tool and used compressed air to hold up the valves. Took me 2 hours to do all 8 cyls. I can't imagine trying to use a generic valve spring tool.
Old Aug 12, 2005 | 02:25 PM
Xtnct00WS6's Avatar
Moore tool from Thunderracing worked great for me. Don't even try anything from a local autozone type place. It won't work!
Old Aug 12, 2005 | 11:20 PM
Ferocity02's Avatar
I have used my Larry tool to do two valve spring swaps on my LS1. It works great! I cant imagine using a handle type compressor to get to the back ones. I used a handle type one from Kragren or Autozone on my friends Cobra. It worked great, but not on an LS1 F-body.
Old Aug 13, 2005 | 12:06 AM
mrr23's Avatar
here's the vinci/crane valve spring tool like described above, it does two at once.
http://www.vincihighperformance.com/superwebdeals.HTML
Old Aug 13, 2005 | 03:41 PM
vettenuts's Avatar
I have also already decided, I am going with the Crane. Going to pick it up from Joe Vince at Corvettes at Carlisle in a couple of weeks. One thing I found is that skimping on tools usually causes more trouble then it is worth.
Old Aug 13, 2005 | 04:56 PM
smask04C5's Avatar
VHP/Crane spring compressor works very well, worth the $
Old Aug 13, 2005 | 09:12 PM
blkZ28spt's Avatar
Crane hands down.
Old Aug 13, 2005 | 10:26 PM
Black Z/28's Avatar
Originally Posted by vettenuts
I have also already decided, I am going with the Crane.... One thing I found is that skimping on tools usually causes more trouble then it is worth.
Another vote for the Crane tool. I've done my springs twice with the Crane tool. And I agree, don't skimp on your tools- consider them an investment.
Old Aug 14, 2005 | 02:16 AM
luv2spd's Avatar
Another vote for the Crane tool! Works great.
Old Aug 14, 2005 | 02:18 AM
jrp's Avatar
jrp
SN95 Director
crane > *
**** that autozone tool, i learned my lesson with that piece of ****
Old Aug 14, 2005 | 11:27 AM
blkZ28spt's Avatar
Originally Posted by jrp
crane > *
Same here. I spent over two hours doing one cylinder with the autozone rental tool. Had the Crane overnighted and did cylinders in 15-20 minutes. Easy as pie.
Old Aug 14, 2005 | 11:35 AM
davered00ss's Avatar
Moderator
Made my own.
Took about 10 min.
Old Aug 14, 2005 | 02:24 PM
blkZ28spt's Avatar
Originally Posted by davered00ss
Made my own.
Took about 10 min.
The downside to that design is that it stresses the rocker bolt, or whatever bolt you use, and some have snapped the bolt off in the head.
Old Aug 14, 2005 | 02:48 PM
2001 SOM WS6 69 GTO's Avatar
Default Tims valve spring Tool
Here is a link to my $ 30 inexpensive valve spring tool:
https://ls1tech.com/forums/tools-fabrication/317675-tim-s-valve-spring-tool-now-available.html
I have sold over a 100 of these tools, and have performed about 20 cam/spring swaps using the exact same tool and worked without a flaw, and had nothing but positive feedback about my tool
There was a DIFFERENT version of a home made spring compresser out there that did have some problems with rocker bolts breaking as blkZ28spt mentioned.
Mine DOES NOT
It takes me 1.5 hours to do a complete spring swap and my tool makes it less likely to drop a retainer keep since you are only dealing with 1 valve at a time. I have used all the other valve spring compressors as well, the crane is nice, but the price it alittle too step for most of us out there that need the tool 1 time.
Old Aug 14, 2005 | 02:56 PM
Moderator
Plan is only to use mine once. Heads next year.
