Help!!! Flycutting?
Old Aug 13, 2005 | 05:51 PM
bigdsz's Avatar
Default Help!!! Flycutting?
Guys, a friend and I are in the middle of a pretty big cam install and already have flycut the pistons but don't know if they're cut enough. The cam is a Comp 242/248 .610/.615 111 lsa, heads are AFR milled .034 and we're going to use .040 Cometics. The intakes have been notched about .100 and the exhausts about .060. After claying intakes have about .080 clearance and exhausts .090, is .090 enough on the exhausts or should we cut more? I don't want to destroy this engine , my friend will KILL me . Help.
Old Aug 13, 2005 | 07:00 PM
ArKay99's Avatar
'Textbook' is .080" on the intake and .100" on the exhaust. The piston is chasing the exhaust valve up so that is why you want more clearance there.
Old Aug 13, 2005 | 08:08 PM
GMPerf's Avatar
You can get away with .080 on the intake and .090 on the exhaust. If you want, you can flycut another 20 thou without problems...
Old Aug 14, 2005 | 08:46 AM
as35thss's Avatar
Default Flycut
Any one else?
Old Aug 14, 2005 | 08:47 AM
as35thss's Avatar
Default Flycutting
To the top.
Old Aug 14, 2005 | 09:58 AM
GMPerf's Avatar
What else do you need to know?
Old Aug 14, 2005 | 10:02 AM
SideStep's Avatar
BUT... what r u going to do with the 228/230 cam????
Old Aug 14, 2005 | 10:08 AM
GMPerf's Avatar
I think their working on his buddys car...
Old Aug 14, 2005 | 11:12 AM
as35thss's Avatar
Do you think we should go deeper on the Exhaust? Maybe another .010. I have heard .100 is best. We have .090 now?
Old Aug 14, 2005 | 11:25 AM
GMPerf's Avatar
I have fly-cut mine just last week on the intakes (very similar cam) to about.125". Don't be afraid if you go over a little.... .105 or .110
