opinion's on final cam choice wanted!!
Old 08-14-2005, 12:15 PM
destroyerSS's Avatar
Default opinion's on final cam choice wanted!!
The cam is a Cam Motion 253/257 642-646 112LSA 110CL, This will go into my 408 w/ AFR 225's.
Old 08-14-2005, 07:21 PM
Good-Bad
Old 08-14-2005, 07:56 PM
NviouSS's Avatar
holy **** that's a huge cam!
Old 08-14-2005, 08:05 PM
gollum's Avatar
Damn that thing looks big and nasty....................Is this a daily driver?
Hell I don't know.
Old 08-15-2005, 05:44 PM
No this is not a daily driver. Just a weekend and maybe a 10 times a year to the track car. I wonder what cam this would compared to a 346CI cam?
Old 08-15-2005, 08:41 PM
gollum's Avatar
Dude,
SLP and AFR teamed up to bring use big cams to use with 225 heads. Check this 402ci cam out 250/246 @.050, 114 lsa, straight up. www.slponline.com
Old 08-15-2005, 08:56 PM
Originally Posted by gollum
Dude,
Why would they run a cam with that split with heads like the 225's??
Old 08-15-2005, 09:15 PM
gollum's Avatar
The exhaust port is very efficient.
Old 08-15-2005, 09:19 PM
Beast96Z's Avatar
I wouldn't think that it was efficent enough to go reverse on. To many sponsors have been having excellent results with the traditional cams, so I'd stick with that. I like the cam he picked out in the first place, but I really hate reverse split cams.
Old 08-15-2005, 09:23 PM
gollum's Avatar
SLP's Reaserch and Development department do not think you would need a traditional split. I can believe that.
Old 08-15-2005, 09:29 PM
Beast96Z's Avatar
reverse split cams.
Old 08-15-2005, 09:34 PM
gollum's Avatar
Beast96Z, How would you know?
Old 08-15-2005, 10:16 PM
Beast96Z's Avatar
I'm not saying that it wouldn't make power, but from the graphs I've seen, revese split cams have the same low-end power of smaller cams. They don't come on until 5500 rpm's or so. Here is a graph comparing 3 cams. The 224/224, 227/224, and the 230/224. Notice the low-end power never increases over the 224/224 cam, even when you take the intake duration up to 230. If I'm going to take the time for a cam swap, I want all around power, not just top end.
Old 08-15-2005, 10:25 PM
gollum's Avatar
Wouldn't the SLP cam give you a more broad power range because of the 114lsa vs 110lsa?
Old 08-15-2005, 10:34 PM
Beast96Z's Avatar
You may have a bit more of a broad power band, but you also decreased your overlap, thus reducing power. The 227/224 in that graph is on a 114 and it didn't make a diffrence. Some may disagree with me, but with the current heads that are offered for LS-X vehicles, I see no reason for a reverse split cam.
Old 08-15-2005, 10:54 PM
gollum, the cam i picked has a 112LSA With A 110CL so that means it has 2 degree's advanced ground in
