918 Hype Survey
I have 30k out of mine and still going strong with cam in sig. Still has stock rev limiter though (6200).
221/227 .561/.569 114+4
238/240 .605/.609 112+2
227/234 .58?/.58? 112+4
Spun 'em all up to 7000'ish and the springs worked great. I'm very impressed with 918's for a single drop in replacement spring. Would I use them again? Absolutely.
They caused false knock in my car above 4500 rpm
Whith those springs I had to turn off my knock sensors.
The problem went away after I changed to comp double springs
anyways, back on topic. Anyone else have anything to add?
Comp makes great springs.
Anyone use 918's for the Trex cam?
I have used 918's and they worked great. I have installed a ton on other peoples cars as well. It's nice not having to change a spring seat.
The one complaint I have is not about the performance, but installation. The beehive design is tougher to install than other springs when using the Crane tool. The top of the spring is smaller and slides around a lot in the tool. If the spring does not compress perfectly straight, it is harder to get the locks in.
But hey, I recommended a set of 918's today to a customer.
