what do u think of this cam for
Old Aug 16, 2005 | 01:21 AM
pdd's Avatar
pdd
Default what do u think of this cam for
the TEA 2.5 heads?
226 230 114+2 maybe .590 of lift
thinking of this cam for my setup. im sick of my car running shitty. figure if a go to a smaller cam maybe driveability with be better
Old Aug 16, 2005 | 08:34 AM
SideStep's Avatar
DUDE!!! you are killing me... I am looking at that exact cam and (finally) going with a 90/90 intake setup and still try to keep 450....
If you go ahead and do it let me know how it turns out....
You probably already know all this: I did some quick, math with several LSAs and ICLs, here are the DCRs (based on my 11.05 to 1 static), Overlap (.050) and Intake Valve Closings (IVC ABDC)
XE-R 226/230 .585/.592
LSA+ICL....DCR....Overlap....IVC ABDC
112+4.......8.74......4..........41
112+3.......8.67......4..........42
112+2.......8.60......4..........43
112+1.......8.53......4..........44
112+0.......8.45......4..........45
113+4.......8.67......2..........42
113+3.......8.60......2..........43
113+2.......8.53......2..........44
113+1.......8.45......2..........45
113+0.......8.38......2..........46
114+4.......8.60......0..........43
114+3.......8.53......0..........44
114+2.......8.45......0..........45
114+1.......8.38......0..........46
114+0.......8.30......0..........47
Good Luck,
Old Aug 16, 2005 | 03:06 PM
pdd's Avatar
pdd
Ttt :d thanks for the info sidestep
Old Aug 16, 2005 | 03:35 PM
Patrick G's Avatar
LS1 Tech Administrator
PDD: 226/230 112LSA 112ICL gets my vote by a long shot. It will make more mid-range power and torque while still pulling some very good numbers up high. You want at least a 45-46 IVC for max power. When you spread the LSA too much, you open the exhaust valve earlier, which could bleed off some valuable cylinder pressure. The 112LSA seems like the best combo.
Sidestep: I'd throw an adjustable timing gear on your current cam and advance it to 111ICL. You will pick up some driveability and mid-range and not lose any top end.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Aug 16, 2005 | 05:34 PM
SideStep's Avatar
Hey Pat...
I am probably going to do it when I get back from vacation in Sept. will keep you posted....
Old Aug 16, 2005 | 05:42 PM
pdd's Avatar
pdd
thanks for the info patrick. will keep my eye out sidestep the only problen i see for me is that my pistons are notched. my heads are milled .024-should i take them off and mill them some more for that cam(226-230) if i went that way?
Old Aug 16, 2005 | 06:59 PM
SideStep's Avatar
Hmm.... not sure.. mine are milled .024 also and I did fly-cut (.080) my pistons... I am guessing (I do not know the Futral cam profiles, I bet Patrick does) that the 226/230 cam would have a greater DCR compared to your F14 given the same LSA/ICLs, soooo... you do not need to mill the heads any more to get a higher DCR, it will get there by going to the smaller cam (226/230)...
Just for example here are the numbers from a CompCam XE-R 232/234 cam... just for comparison, obviously these numbers will not match your Futral cam exactly... I did these using my 11.05 to 1 compression... Your DCRs would be slightly higher...
112+4.......8.53......9..........44
112+3.......8.45......9..........45
112+2.......8.38......9..........46
112+1.......8.30......9..........47
112+0.......8.23......9..........48
113+4.......8.45......7..........45
113+3.......8.38......7..........46
113+2.......8.30......7..........47
113+1.......8.23......7..........48
113+0.......8.15......7..........49
114+4.......8.38......5..........46
114+3.......8.30......5..........47
114+2.......8.23......5..........48
114+1.......8.15......5..........49
114+0.......8.08......5..........50
Old Sep 28, 2005 | 10:37 PM
pdd's Avatar
pdd
ok i got a fms 226 230 +4 112lsa . im gonna put the ivc on 45 by running 112+0 . since i have a stock bottom end i dont wanna spin it to the moon either. maybe shift light set at 6500rpms. what do you think? or should i try 112+2 ????
Old Oct 4, 2005 | 02:32 PM
gomer's Avatar
The "gomer grind" rev. 2 cam that I install in alot of local cars is a 226/228 114 +2 using X-er lobes. Hold on a sec and I'll stick up a graph of a cam only car I installed one in just the other day.
The car below is a 2000 Z28, flowtech headers, magnaflow catback, LS6 intake, underdrive pulley, 918 springs, and a Bo White Tb.
Old Oct 4, 2005 | 04:25 PM
1fastWS6's Avatar
I can't imagine that the cam your contemplating will be any better than the F14 as far as driveability goes....if it's the standard F14 with a 112lsa / 108icl that is. If it doesn't have any advance ground in, I'd advance it 2-4 degrees and see if that helps first. You can easily install an offset bushing in the stock cam gear to advance it if you don't have an adjustable chain already.
BTW, Sidestep.....where are you getting the DCR calculator? Have a link? I've only seen one out there but I needed a login to use any of the calculators....PITA.
Old Oct 4, 2005 | 06:19 PM
pdd's Avatar
pdd
you dont think the 226 230 will idle any better than the 232 234?
Old Oct 4, 2005 | 06:21 PM
MattIROC's Avatar
whats wrong with your 232/234 cam? is it tuned?
Old Oct 4, 2005 | 06:38 PM
pdd's Avatar
pdd
I had it tuned a few times but it still doesnt idle great. so i hope a smaller cam will help me out
Old Oct 4, 2005 | 07:33 PM
Slowhawk's Avatar
LS1Tech Sponsor
I would say drop it off and have it tuned as promised
Other than that we have good luck with a few different Cams.A populer one is a 228/232 and the other is the 232/234.But we have them ground a certain way to give excellent idle/drivability. Not rocket science but different than the Cams listed above
Old Oct 4, 2005 | 07:38 PM
pdd's Avatar
pdd
Cool Pic Don 90 percent sure ill have to wait till spring to get it back to you. but who knows i might be able to beat the snow
Old Oct 4, 2005 | 08:19 PM
JakeFusion's Avatar
Super Hulk Smash
I say go for the G5X3-114. With all the bolt ons you have, might as well aim for 500rwhp. You don't hear about any tuning problems with the G5X3, even though it is bigger than your F14. Hell, I don't hear much in the way of the F14 or F15 being better than the F13 in terms of power, so might be worth a shot, and drivability can't be any worse.
I still say there are some other problems with your car if it won't hold a tune. I'm curious to see how you get it resolved and what sort of power you end up with.
Old Oct 4, 2005 | 09:07 PM
vegascamaross's Avatar
I'm running a 230/232 112+2 on xer lobes and it drives quite well. I have not put her on the dyno but my butt tells me theres more power! Oh yeah I just bought HP tuners and have been tuning as I learn so not the best tune. Still drives real nice.
