LS2 block, worth it?
i know the LS1 is an amazing engine, but i know im gonna wanna bore/stroke it and i know the cost of resleeving the ls1 isnt worth it compared to just goin for an ls2 block and boltin everything up.
pretty much what im getting at is should i build off the LS1 or go for the LS2 block, which is more cost efficient/ in the long run i can do more with.
on a side note, how much can you bore the LS2 to w/o resleeving? How many of you guys are using LS2 blocks and what kinda numbers are you puttin out....thanks in advance guys, im gonna need alot of your guys' knowledge/experience in the near future.
You will need a little more than 5-8k to get everything done for the 40x cubed LSx (either an iron block 40x or the ls2 based 40x). Clutch, hydraulics, (go with the Aussie clutch setup) rearend, suspension pieces, fuel system upgrades (pump/injectors) tuning, etc.
Do both SDPC/SLP setups come with the cam position sensor, covers, everything to retrofit the LS2 into a LS1/6 setup?
Going with a forged stock CI shortblock is nice, but then you still dont have the ability to make the same power as a big cube motor...
Unless you go all out turbo, then its a proven fact that smaller CI will make more with whats available now..
Edit: link https://ls1tech.com/forums/signature-testing-design/356036-signature-faq.html
https://ls1tech.com/forums/generation-iv-internal-engine/357798-texas-speed-402cid-ls2-short-block-special.html
Best deal I've seen so far.
https://ls1tech.com/forums/showthread.php?t=357798
*salivating*
