AFR 205s+LS2 402?
Old Aug 21, 2005 | 02:55 PM
tonyb's Avatar
Default AFR 205s+LS2 402?
I currently own 66cc AFR 205s with no milling stock out of the box.With a LS2 402 and flat top pistons w/2cc reliefs,what kind of compression and results in general will I be looking at.This is a street car with occasional trips to the track.All the supporting mods in sig would be swapped over.I would only be changing shortblocks and a decent camshaft change.Any recomedations would be appreciated.
Thanks
Anthony
Old Aug 21, 2005 | 03:38 PM
lsx24's Avatar
That looks like a very good combo. I do know the stock compression ratio of the ls2 is 10.9, sorry I can't help with the other question.
Old Aug 21, 2005 | 03:55 PM
muraoka's Avatar
i think 10.9-11.0 should be right. i have -6cc pistons and have 10.85 to 1.
matt
Old Aug 21, 2005 | 04:11 PM
jrp's Avatar
jrp
SN95 Director
your looking at near 12.0 CR with a .040 cometic and -.008 deck height. keep in mind 402 = 4" crank. longer crank = more SCR. you'll need a larger dish or larger chambered head to bring the compression down.
Old Aug 21, 2005 | 04:37 PM
Brandon Boomhauer's Avatar
What is the typical deck height on a 402/408?
Old Aug 21, 2005 | 05:40 PM
tonyb's Avatar
12:1 would be good for me.I do little driving and with my experience with the 205s so far,there will be little detonation.Has anyone done this combo of 205s and a 402/408 yet? I would like to get some feedback on powerband and what kinda power I should be making and any kind of recommedations from there.
Anthony
Old Aug 21, 2005 | 06:47 PM
Cary@Perf-Induction's Avatar
Collections Hold
Default torque
Anthony
with such a small intake port cross sectional area, it will be a torque monster. a 225 cc head would make quite a bit more power without a loss of low end, granted you already have the cylinder heads, you may want to run a little more duration than you would normally see on a 346.
Old Aug 21, 2005 | 07:07 PM
lsx24's Avatar
For such an application I would get worthwhile heads for sure..
Old Aug 21, 2005 | 09:26 PM
Are you talking about running a set of 205s on a 402 with something into the 25x range?
I know the 24x range on a 40x ci motor is pretty tame..
Old Aug 25, 2005 | 08:46 PM
lsx24's Avatar
Cool
Old Aug 25, 2005 | 11:28 PM
GrannySShifting's Avatar
that head I think is just too small for a 400 inch motor tony. Definitely going to need to run some more cam, even a 230 duration cam Id keep the ICL 110 or higher and try and bleed off cylinder pressure, and try and feed that motor through the little head
Old Aug 26, 2005 | 05:29 AM
lsx24's Avatar
Ok, if I was on with a choice of 205s or 225s per say for a 346 now, but planned on increasing displacement in the future (possibly a 383 a bit later), what heads would be wise to go with?
