Ported heads question...
I used the high temp RTV GM sealant when I put on the intake rocker bolts...will that be fine? I jut put a little on the upper part of the threads.
Whats everyone else use for that?
because they are ported, the bolt holes are exposed in the intake ports. if you screw the rocker arm bolts in you can see them in the ports...many ported heads are this way.
edit: i should have been more clear. the thread holes for the rocker bolts are exposed so they need to be sealed, the exhaust side does not have this problem.
