Budget Shortblock rebuild
Old Aug 7, 2005 | 09:20 AM
nytoy's Avatar
Default Budget Shortblock rebuild
So found out the rings are toast, burning oil. Top end of the motor looks fine. Basically wanted the cheapest and fastest way to replace the rings. No no2 or F.I. will be going on the motor. Used mostly for track days, lapping, so I was curious what the cheapest way would be. I also dont want to assemble the shortblock myself, I'm find with pulling the heads and stuff. Can I just take the block to a local machine shop and get it honed for stock pistons and use some super nice rings?
Old Aug 7, 2005 | 10:12 AM
conan's Avatar
Just my $.02 But get some new bearings (rod,crank,cam) while your in there there not that much money. The hone will do the job if the cylinders aren't scratched.
Old Aug 7, 2005 | 10:21 PM
nytoy's Avatar
anyone else?
Old Aug 8, 2005 | 03:00 AM
Jimmy P's Avatar
How many miles are on it? What type of rings are they?
Old Aug 8, 2005 | 03:38 AM
DONAIMIAN's Avatar
Ive seen forged motors go for as cheap as 2500. Thats not a bad price, and even though you said it would never see a power adder, I would also go forged for the higher RPM capability.
Old Aug 8, 2005 | 09:50 AM
Demon SS's Avatar
we could help you with a forged bottom end. we have one that can ship by wednesday if you are interested.
Old Aug 8, 2005 | 11:52 AM
magius231's Avatar
IMO if your going to go as far as this, save up a little more money and do it right. get it honed or bored if needed, replace the bearings and pistons (if needed), get everything checked/magnafluxed/cleaned and if your planning on any power in the future take that into account and get the stuff done now. Your short block is not the place to skimp.
Old Aug 12, 2005 | 10:28 PM
nytoy's Avatar
I agree, I'm not going to write off stuff if it needs replacing, in fact I wonder if there's a "while I'm at it list" The bottom end bearings are a given. Ported oil pump? Timing chain? Which rings are the best?
I will get a hone, and hopefully that's all it will need along with some rings. What about ARP rod or bottom end bolts that are stronger for rpms?
Old Aug 13, 2005 | 10:29 PM
leaftye's Avatar
The "list" is just going to get you in trouble. You could do the following for "reliability"...
Two piece timing cover
Billet main caps
Katech rods bolts
QTP oil pump
Engine and tranny cooling...cuz the tranny is coming out too right??
New lifters, or step up to Jesel/Morel
Update the PCV
Crankcase vacuum pump
....you don't even want to start doing stuff to the heads...you know, to improve "reliability".
Old Aug 14, 2005 | 10:15 AM
DriveATransAm's Avatar
i had a pretty budget rebuild. i had a bad ring and had to take mine out. changed all the bearings, and rod bolts. i left the stock rods cause i didnt have the extra cash to put down on a budget motor that wasnt gonna see fi or anything. i got new forged/reliefed pistons cause the problem was actually one of my pistons. my engine is so quiet compared to the stock pistons now its amazing. in the end the engine guy charged me about 1500 i think to hone the block, clean everything up, put it all back together. that was parts and labor. i did go with a different head/cam as long as i had the engine out. other than the engine stuff i didnt change anything else. maybe i like living on the edge i bought a built trans at the same time so i didnt have the extra cash to put into a motor. otherwise i would have gone with a built 402 by one of the sponsors
Old Aug 15, 2005 | 10:29 PM
nytoy's Avatar
Hmmm so anything else I should be looking at? New stock GM lifters or does it matter?
Old Aug 18, 2005 | 10:13 PM
nytoy's Avatar
What kind of pistons are decent? Should I bother replacing the lifters?
Old Aug 18, 2005 | 10:24 PM
ArcticZ28's Avatar
Oh man, you have no idea what you're getting yourself into with the "while I'm at it list"... been there, done that.... and doing it all over again as well. Good luck
Old Aug 22, 2005 | 02:32 PM
magius231's Avatar
yeah the while I'm at it list ends up being a forged 427 high compression solid roller TH400 backed race motor by the time you get done with it...how many people have fallen into that trap i wonder
Old Aug 22, 2005 | 02:36 PM
ArcticZ28's Avatar
Diamond's and Wiseco's are both very good depending on the application. While you're at it you might as well go ahead and replace the lifters with Comp OE replacements, or the Comp R's if you're feeling ballsy. Some have had good results and some have had bad, up to you.
