Block/head bolt????? HELP
Old Aug 23, 2005 | 08:28 PM
HASTINGSRJ's Avatar
Default Block/head bolt????? HELP
OK, so I broke a head bolt off in my block. Now I have exhausted all means of trying to get the bolt out, without any luck, But my question is: What if I tap the bolt hole and find a shorter, wider bolt to hold the head down??? Do you think this will work?? I mean worse case I **** a head gasket out, but I already have to buy a new block so...its worth a try. Gimme your opinions on this.....I really need help over here. I was supposed to drive to NC today, but had to delay my trip. I am getting stationed there......
Old Aug 23, 2005 | 08:51 PM
Inspector12's Avatar
TT-TECH Veteran
I know of one person that has done this with a shorter custom stud and it worked fine.
Old Aug 23, 2005 | 10:50 PM
HASTINGSRJ's Avatar
REALLY....did he start tapping it from the top of the block?????
