Anyone pull a motor topside with the heads on it?
Old Aug 24, 2005 | 09:47 PM
lotsaLS1's Avatar
Default Anyone pull a motor topside with the heads on it?
looking to do this --my problem is i dont know where i can grab it from --i dont want to crack the block or heads -its a good motor that has been good to me ,just needs new bearings
Old Aug 24, 2005 | 10:13 PM
jrp's Avatar
jrp
SN95 Director
bottom > top
been there done that.
Old Aug 24, 2005 | 10:14 PM
WILWAXU's Avatar
I hooked mine on the passenger side head and on one of the assesory bracket bolt holes on the drivers side front.
You should be alright as long as you use a bracket mounting hole and not one of the water pump mounts.
Old Aug 24, 2005 | 10:15 PM
SUX2BU's Avatar
they are both pretty easy. i just bolted a chain to the motor mount bolt holes.
Old Aug 25, 2005 | 02:51 AM
Lvmyz28's Avatar
are you replacing rod bearings or main bearings? You can do the rod bearings in the car, but to do the mains you have to pull the tranny out. I guess if you really wanted to you could do those in the car as well, but holding the crank up and putting the mains back on would be a bitch! Out the bottom if you have a lift, out the top if you only have a cherry picker!
Old Aug 25, 2005 | 12:41 PM
bulletLS1's Avatar
I pulled from top.
I had to remove the tranny halfway thou.
the manifold rubbed very hard against the top rear part of where the wipers seat, I removed the radiators, the windshield wipers and all plastic thing bellow the wipers (broke the windshield )
CAREFUL with some grounds in the rear of the drivers head (of the car BTW! )
and a bunch of connectors hiden when you tilt the engine (cam sens among others).
Old Aug 25, 2005 | 12:47 PM
lotsaLS1's Avatar
Well I'm redoing rods and crank bearings -i have a big bore for the car -but I wann sell this motor sometime in the future -so i'm going to have the crank cut and make sure its a good motor for the future owner -it spun a rod bearing "my fault thow" I raced someone with the car ice cold "oops" but it only has 34k on it so the rings and schtuff are good never been sprayed ect. Well i'll eye ball the bolt holes you guys said I just wanted to be sure
Old Aug 25, 2005 | 12:56 PM
SUX2BU's Avatar
Originally Posted by bulletLS1
I pulled from top.
You didn't have to do all that.
Just pull he tranny, exhaust manifolds, intake, crank pulley, all accesories and make sure you get all the wiring off of it. Then it just slides right out.
Old Aug 25, 2005 | 12:59 PM
Derek98z's Avatar
pulled from both top and bottom. I prefer the top by far.
Old Aug 25, 2005 | 01:39 PM
SUX2BU's Avatar
Yeah the top is easier but it takes ALOT longer.And besides how mant people have access to a lift when ever they want?
I can got the motor and tranny on the floor in about 30 min last time i pulled mine out the bottom. About an hour to swap everything over to the new long block, then another hour to put it back in the car. about a 3 hour job of swapping motors.
Old Aug 25, 2005 | 02:16 PM
ninobrn99's Avatar
Juans the man at that ****!! 3 hours for a swap i pulled one from the top. a chain went from the back of the driver side head that crossed over to the front of the pass. head, then another chain from the pass. front to the driver front, put a turnbuckle on it and lifted it out that way. tranny was taken off before the pull though and we didnt have a leveler, just the cherry picker. be sure to get the grounds off the driver side of the block. just follow the front o2 sensor and ye will find. i think its 3 grounds on the driver head and 2 on the pass. someone can correct me if im wrong. we took the intake off and the oil pressure sending unit.
Old Aug 25, 2005 | 06:44 PM
lotsaLS1's Avatar
yah i have it ready to go --i took about 3 hrs for me also i just wanted to be sure about a few things -i removed my intake and crap -so i guess she will come out sat when i have time --imo the ls1 is a very easy pull .But its better to be safe than sorry --if it was blown up - i wouldnt care but it just needs minor bottom end work
Old Aug 25, 2005 | 08:10 PM
SiL3NtXWS6's Avatar
I got mine out the top with heads on in less than an hour.Got it back in in less than an hour too.
Old Aug 25, 2005 | 09:46 PM
98z28chevy's Avatar
I took mines out from the bottom its not too bad at all. I think putting it back in gonna be the fun part this sat. i plan on getting my 04 z06 motor running in my 98z cant wait.
