How to turn crank when degreeing cam...???
Old Aug 27, 2005 | 06:54 PM
SideStep's Avatar
Question How to turn crank when degreeing cam...???
Subject says it all... Looking for ways to turn the crank and not accidentally move the degree wheel.
Old Aug 28, 2005 | 09:44 AM
bowtieman81's Avatar
Excellent question. I am not sure the best way to do this either. I am going to try and use a strap wrench wrapped around the crack snout. I hope there is enought room to get my had in there. I have the oil pump off the engine, so might be able to make it.
Old Aug 28, 2005 | 09:54 AM
SideStep's Avatar
That is where I was headed also... not a lot of room behind the degree wheel.
Old Aug 28, 2005 | 03:21 PM
as35thss's Avatar
I used the Comp Degree wheel. You must take the oil pump off. Mount the degree wheel on the crank with the crank bolt. Get #1 as close to top dead center as possible. Put 0 on top of the degree wheel up, and install your pointer. Double check TDC and adjust you pointer to 0 on the degree wheel. Now use the crank bolt to turn the motor over.
Old Aug 28, 2005 | 03:39 PM
SideStep's Avatar
Maybe it will be ok turning it that way... I am afraid of moving the degree wheel (in relation to the crank) after I have TDC on "zero"
Old Aug 28, 2005 | 03:44 PM
as35thss's Avatar
Once the crank bolt is tight. The degree wheel is not going to move. Move the pointer if you need to move anything.
Old Aug 28, 2005 | 03:59 PM
slowpoke96z28's Avatar
or use a flywheel turning tool
Old Aug 28, 2005 | 04:32 PM
SideStep's Avatar
I could but I did not want to drop the headers to get the inspection plate off....
I am getting way too stressed over this.... must go
Old Aug 28, 2005 | 05:09 PM
ArKay99's Avatar
When I did mine I used the comp wheel too. I did TDC on #1 and set the pointer on the wheel. Then I turned the motor over with the crank bolt until TDC on #1 and checked evrything. It stayed where it was. It didn't take that much to turn it over with no spring load on the cam and with just the one head and checker springs. Iwas just really careful and checked everything several times. I spent most of the afternoon doing it. I used a Cloyes Hex-Adjust and got it exactly where I wanted it.
Old Aug 28, 2005 | 05:11 PM
2001CamaroGuy's Avatar
I did the same as everyone else......put the degree wheel on the crank bolt and tighten the crank bolt.....once tight, the degree wheel won't move.....
Old Aug 28, 2005 | 07:19 PM
as35thss's Avatar
It is diffently the easiest way to do it. Hands down.
Old Aug 28, 2005 | 08:30 PM
SideStep's Avatar
Cool...
Thanks to everyone for options....
I guess I am going to use the crank bolt method.
...I am too drunk to do anything now anyway
