4000 stall, Which cam?
Old Aug 28, 2005 | 11:19 PM
TA4U2NV's Avatar
Default 4000 stall, Which cam?
Welp, new to the world of cams, and looking into one, I need one that would match well with my 4000 stall. What all is needed for a cam swap, and what would be a good sized cam to match my stall? Any help/info is appreciated!
Old Aug 28, 2005 | 11:41 PM
josh99ta's Avatar
Sold The Fun Stuff :(
With a stall that big you can go with just about anything. My 221/221 is a great cam for my 4000 stall, but I feel I could go much bigger. You really want something that does well from 5000+ as that will be your shift extension after you get going.
Old Aug 29, 2005 | 10:15 AM
lsx24's Avatar
A medium stall may not be a perfect match for a larger cam, though a smaller cam is fine for a larger stall. I spent some time with a 2800 and it was great for the stock cam...That is a very big stall, you might be able to or go ahead and estimate matching a 4000 stall with something like the f13 for instance.
Old Aug 29, 2005 | 07:59 PM
TA4U2NV's Avatar
TTT, how do you match your cam and stall? What do you look for?
Old Aug 29, 2005 | 08:07 PM
Z28_Ninja's Avatar
you look at where the shift extension of the converter is going to drop you into the rpm band, then you want to find a cam that makes good power where the stalls shift extension leaves you.
Old Aug 29, 2005 | 09:34 PM
blkZ28spt's Avatar
My MS3 (237/242 .603/.609 113) matches up to my 4k stall pretty well. Shift points are set at a slightly below optimal 6500 for the time being.
Just about any cam that could be considered totally streetable for a daily driver should be okay with a 4k stall, you'd have to get a pretty big cam to need a stall larger than 4k. This means the question turns into "what cam do you wan?" and not what cam can you get. SEARCh and read the cam guide sticky for help their. If you want pretty big but still daily drivable (after good tune) look at the TSP MS3, HPE S, LG G5X3 and others in that range.
Old Aug 30, 2005 | 02:35 PM
TA4U2NV's Avatar
ttt, i'm looking for a cam thats a good size, makes good power, possibly 23x/23x or something around there. Any recommendations?
Old Aug 30, 2005 | 03:15 PM
TA4U2NV's Avatar
How about a TSP 231 231 598 598 112? Seems to be a good size cam, but how do you determine where a cam makes it's power?
Old Aug 30, 2005 | 03:57 PM
Chuck@'s Avatar
A 4000 stall would work fine with an S cam. For an all out race only setup, a 4500-4800 stall would be better, but for a daily driven type car, a 4000 will be fine. We put 3600, even as small as 3200 in S cam cars all the time, and people love them.
Chuck
