Just curious....cam for 9k rpm?
Huge port heads (ls7, c5-r, ETPerformance), shaft rockers, titanium valves, huge lift solid with around 15 degrees of split between the intake and exhaust on a 110-114lsa (heads, intake, exhaust, compression will determine this), triple springs, sheet metal or 4 barrel single plain intake, good engine builder, 2" primary headers 3.5 " collectors headers, belt drive, dry sump, and a whole lot of other things. Oh, and a huge bank account.
you'll probably have to run half a quarter of zero weight oil in it too! haha. cam duration in the .600@.050 range, 2" lift, 102 lsa, 5" bore, 2" stroke and some sort of superpolyolioid valve springs........... and the laughs just keep on coming.
Didn't see that this just asked about cams. Ok.
For example purposes my friend's building a 400 inch sb2 motor with 13.3 or so to 1 compression. Going to spin 8000-8300.
Cam is 276/284 111 lsa, .805"/.805" lift. His heads flow a peak of 405cfm @.800"/274 @.800". Headers are a 1 7/8" to 2" primary with 3.5" merge collectors and a 4150 flange short runner intake.
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
Insane....I'm gonna make an understatement and say that's not a street car.
Why the 2" stroke? What's the theoretical optimum R/S ratio(1.74?) for LSx motors? LSx can be made a square b/s motor pretty easily with 4" bore and stroke.
Aussie Ls1 has a big HP motor in his car that runs to 8,000 rpm and the only reason why it dosen't run higher is that there is not a table in the factory PCM that will support more than 8,000 rpm not that the engine could not turn any harder......
And no it does not have titanium rods just a set of crower sportsmans and a factory crank as well. But the cam is one big custom solid ****** F*&^er, the specs of which he will take to the grave.
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
