My Ls1 Eats 5w30 like she burns gas
LS1TECH Sponsor
Originally Posted by GM Muscle
I used to go through a ton of M1 5W30. I switched to M1 0W40 and I hardly ever add any oil now, even with all the abuse I put it through.
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
5w30 burns like water 0w40 mobil one i use maybe 1/2qt every 3000 unless im racing but high rpm and high rpm decel will always burn more
5W30 dino and no oil consumption issues since I bought the car in May 2004. I never added more than 1/8-1/4 qt between oil changes. I switched to 5W30 semi-synthetic about 2 weeks ago, not sure of the outcome yet. Engine is stock as far as PCV system, no oil catch can, etc.
Originally Posted by slt200mph
Fill me in on you oil analysis Patman..who did yours..I should get one done I am curious on my content..
http://www.bobistheoilguy.com/terry.html
If you like Mobil1 then 3 qts of 5w-30 and 3 qts of 15w-50 makes for a good mixture that resolves most consumption issues. This is the mixture that XTrooper used to solve oil consumption issues in his car a while back.
Although a few of you describe problems so bad that a viscosity change isn't likely to resolve things.
I also have a car that burns no oil over 8K miles.
