408 stroker parts
Old Sep 4, 2005 | 12:29 AM
black4x4's Avatar
Default 408 stroker parts
going to be building a 408 for the truck and have been looking at whats out there to do it and have come down to using eagle crank and rods with je or dimond pistons. how will a setup like this work for something that will maybe see 6500 max more likly to see 6000. and down the road 100 to 200 shot of nitrous. and would it be a good idea to go arp mains or would stock be good, and for sure i'll run arp rod bolts.
Old Sep 4, 2005 | 12:32 AM
Brandon Boomhauer's Avatar
go ahead and get arp mains.
what heads will you be running?
heads and the cam selection will determine the rpm you will run.
200 shot will be nothing, just gap the rings properly.
plasmamoly will be fine, no need to go to a hellfire style of ring.
Old Sep 4, 2005 | 12:37 AM
black4x4's Avatar
cam wise nothing bigger then 230/230 and eather some worked 317 heads or ls6s with some work done to them. i want this motor to have massive torque from clear down low. it will be for the truck in my sig.
Old Sep 4, 2005 | 01:18 AM
yeah it for sure needs alot of TQ.
do a little searching, within the last few weeks there was a nice discussion about a TQ cam...
Also search on performance trucks. although i'm sure you are on there...
Old Sep 6, 2005 | 10:20 PM
black4x4's Avatar
when i do this all i should need from a 6.0L is the block and heads if i decided to use 317 heads over ls6 ones. everything else should be new or i should be able to get it off my 5.3. or is there more then just the block i need?
Old Sep 6, 2005 | 10:28 PM
Ferocity02's Avatar
The Eagle rods should come with ARP bolts, most rods do. ARP main studs are a really good idea. I'd also suggest a larger cam. That cam is mild for a 346, small for the 408. The larger cubes "eat" up the the cam a little more. I would suggest something in the 240's with correct split, lift, and LSA for nitrous. I don't know what split and LSA N2O cams like.
Old Sep 6, 2005 | 10:44 PM
ferocity, you think a cam that big would be nice in a heavy *** truck?
Granted 2500rpm should be over 400ft lbs with a mid 24x cam though...
Old Sep 6, 2005 | 10:51 PM
Ferocity02's Avatar
a 240's duration cam would be considered mild in a 408. Like a 224 is in a 346.
Old Sep 6, 2005 | 11:30 PM
I know, but for massive lowend, I'm thinking a very small 240 maybe even a 238/240 might be better.
Old Sep 6, 2005 | 11:38 PM
Ferocity02's Avatar
I am not sure what he is looking for. A low LSA and some advance in the cam should help build a little more low end torque.
Old Sep 6, 2005 | 11:48 PM
MAC4264's Avatar
He should use a small cam and small headers to build that lowend he is looking for. Bigger is always not better even if your adding cubic inches. Being conservative will pay off. There is people on this forum that have bigger cams at .050 than some pro stock motors.
Old Sep 7, 2005 | 05:57 AM
black4x4's Avatar
so i should only need the block and as far as the cam goes what a couple of you guys said is what i'm thinking right now in my 5.3 i have a 210/218 551 lift cam its mild as hell to you guys but for me its just a hair big. so i figured when i went to build this go low and have plenty of bottom end and then when i have money maybe go alittle bigger. but now i was thinking something mid 220s to low 230s with upper 500s lift and low duration on a 110 or 112 lsa.
