Why did my Z06 dyno so low? Lots of mods, low numbers
I planned on upgrading to a 408 later, but i dont have the motivation now with the dissappointing results. I wanted my mods to last throuh all the mods, nitrous, stroker, and things of that nature so i bought resonable parts for them. It still should work on a 346 though. It should be alot higher IMO.
Well i drove it around for 2 weeks without muffelrs and noticed no difference after we put the mufflers on so i dont think they are a restriction. They are straight through mufflers like bullets but more of a GMMG style. The car sounds the same, just a tiny bit quiet with them on. Also im not doing the Fast stuff until this car gets fixed. If it can't make more power with the setup then i am not going to waste more money on it.
You could raise your SCR with some thinner gaskets PTV allowing. This will also improve your quench. Also lean it more for a 12.8>13.0:1 AFR while raising timing till no more power is made then reduce it another 1*. What is the advance ground in the cam?
Originally Posted by Shawn MacAnanny
So are these typical numbers for your cam Chuck? If i switched over to the Trex like i had orgionally wanted, would i see a 50rwhp gain? BTW Chuck you tuned this car for Fran Schatz of Clayton, Delaware (My mechanic). I believe be said he even called you after the dyno run and asked you why thse numbers were so low, you said thats normal without a 90/90 so is it because of your cam?
Switching cams is not going to yield much for results... Definitely no where even remotely close to 50 rwhp. We designed the S cam with a stock shortblock in mind. That cams out there winning races, so whoever tries to tell you differently you just need to stop listening to them!
For example. When you race somebody with your car, what's the lowest RPM you ever see in your ZO6 after 1st gear? Something like 5k rpm right? Ok, so do we really care what the car makes under 5k rpm? No, but still the cam does good below that, just trying to state a point. You know that power up top when you pull on somebody because their using a smaller cam on a tighter LSA because they wanted more torque down low? Well that's what the S cam is all about. Winnin races. I heard a story about how your car kept up with a car that had 580 rwhp? They only put 1 car length on you? Well if you ask me, it doesn't sound like your car is doing all that bad. Gotta keep in mind that possibly this dyno you guys went to reads a little lower than most.
I know for a fact that if I was there right now I could pull 430 out of it without doing anything but porting the tb, and tweaking on the tune. So all things considered, your numbers aren't all THAT bad, just not completely optimized.
With a free'd up intake and exhaust I think the car would put down around 450-460 rwhp fully optimized. You'll just have to get with your mechanic on that, and I'll take care of you on the tuning.
Chuck
what kind of dyno was this on? if it was a mustang dyno, there is the reason for the lower numbers. i have a friend that dynoed his formula on a mustang dyno and it only pulled 330, but he runs low low 11's...you do the math
Didn't read everyones comments but based upon your graph, I'd say your tuning will give you another 10-15 rwhp. You could have too much timing and your fueling is rich on the big end.
Shawn,
Dont throw in the towel. I bet it is something you are over looking. Like others said, you are down on power.
Your mail order puter tune can be way off. Not everyone gets 450 out of their motors. It looks like you are trying hard to get it though.
Go back over the basics.. Always a good place to start!!
JMHO
JMHO
#32
Lol im not sure about the 580rwhp race story. I am setup for a race against an R6 here shortly and from a 50mph i did gain 4 cars and pass an 01 Viper GTS on your mail order tune so it's not running bad or anything, i just dont think it's at it's full potential. I wish Fran had dynoed it before so we could see how much it gained. It does sound awesome. I really dont think the mufflers are restricting at all. The are straight through mufflers, kind of like GMMG. They look like a reversed glasspack with no glass packing.
The car was dynoed on a Dynojet. I have no problem with low end power, but i am thinking there could be more top end. I ran a full 0-1 mile run tonight. At the end of the mile my speed was 170mph which isnt too bad. The Ford GT is at 171 according to R&T so im sure how i should take that. I think it should do better so i figure is some stuff to work out. I dont think they messed with your tune too much Chuck, so i'm not sure what happened with that. They didnt make a pull before they messed with it either so who knows.
#33
Yeah, the tune is fine. There's probably 5 or 10 more by leaning it out assuming it doesn't detonate. But your a/f looks pretty good. And I've got the timing set where and how I like it. If you want, I can come up there and tune it for you. I normally charge 1000 for on site tuning, but since Frans a buddy of mine, I'll hook you up. Just let me know...
Chuck
Chuck
#34
Biggest problem IMO is compression. Maybe you ran this combo with stock pistons and didn't want to flycut. Pull the heads, mill them 30 thousands, run a .045 gasket, port the TB retune and add 25-30 HP.
Your power is low.
I guantree running 11.3-11.5 will make a hell of a difference.
Your power is low.
#35
Originally Posted by SideStep
Shawn,
The TRex would make more TQ based on the tighter LSA/ICL, but needs to be spun higher and is a nasty beast on idle (or to get to idle), also it does not like cats, I am not sure if you are using them.
To be honest with you, your current mods look more like a big cubic inch package compared to a 346 system. You can get away with wider LSAs and big runner volumes on bigger displacement motors. Strokers and big inch engines inherently have more TQ down low and you can bias your mods to help it breath up high in the rpm range and not hurt the bottom end. Unfortunately, this does not work on small displacement engines that need port velocity, high DCR, and good quench to build low-end power.
I know you don't want to hear this but it would probably ROCK!!! on a 382/402/408...
#37
yo Shawn dude i saw your car first hand man and that thing is sick lol i am always at frans shop he's a buddy of mine and those injectors for $300 are mine Frans gonna do my 408 + T72 Turbo build in my car late september dude we should meet up some time man i am always in the mood to hear that thing man i almost nutted myself when Fran fired it up lol shoot me a PM.
#39
heads heads heads... I have the afr 205s with a baby tr224 112 and put down 440 corrected. I had a problem with valve springs and harmonics with the stock afr springs, fixed with thier upgraded spring. My ported ls6 heads only put down 410 corrected so maybe exhaust runner has alot to do with it. My afr heads are out of the box, I am using a .040 commetic and have full bolt ons. Did you fly cut your pistons? Maybe you slightly bent a few? should show up on a dyno though. I also agree that you do not have enough compression for that cam and head setup.
#40
Well the entire cam/head setup is contrary to what i wanted. Fran Schatz picked everything. I had a list of what i wanted installed, he decided none of it was ok so he assured me this setup would make huge numbers on my stock shortblock. I guess he was wrong.
No we didnt flycut the pistons. The first set of heads were milled unbeknownest to Fran and he bent all the valves on the first start up. So we sent out my heads to get them worked, no milling, and it seems to work fine now. I was wondering if they were slighty bent myself.
Chuck do you think that you cam has enough clearance with stock unmilled LS6 heads? Also thanks for the the tuning offer but i live like 2,000 miles away otherwise i would definately take you up on the offer.
No i didnt check fuel pressure. See i paid about $9k to Fran to do this work and have it all tund for me. He promised me the car could go 10s with this setup and that he would have it all dyno tuned and such. I am only 18 years old so when i spend $9,000 it had damn well better do what it's supposed to. I'm just a little dissappointed.
Thanks SS02. I saw your car too when i picked the vette up. Very clean man. Killer setup you're doing too man. My AIM and Yahoo is ShawnMacAnanny if you ever wanna talk.
So the bottom line is the setup i have is crap? I should have gone with 5.3L heads, and a different cam? I wanted the Trex or the G5X3 cam. If i put in an iron 408 like i planned on, what could i expect from that? Would all of my numbers skyrocket?
