Blue smoke?
Old Sep 6, 2005 | 09:14 PM
ohhiitznik's Avatar
Default Blue smoke?
When I hold a gear up like say Im riding along in first at 20-25 mph and I let it just rev itself down, I get smoke coming out my tailpipes. Ive been checking my oil level and it hasnt been dropping. What else could be causing this? I will be getting a new cam/valvetrain next summer in hopes that will relieve that problem. anybody who has had this problem feel free to post
Old Sep 6, 2005 | 09:18 PM
c5dream's Avatar
Could be dumping fuel on deaccel. Do you get a popping noise through the exhaust?
Old Sep 6, 2005 | 09:19 PM
GDM Z28's Avatar
i know on hondas (maybe its different on ls1's), but if your in a gear and let go so the car is in gear and slows down by its self (you will be in deep vaccuum) and it smokes it usually means valve seals. Does the car smoke at idle? what if you let it idle for a while then tap the gas? How many miles on your car and what weight do you run?
Old Sep 6, 2005 | 09:20 PM
GDM Z28's Avatar
usually when you burn too much fuel it smokes black....blue smoke is a plain give away for oil.
Old Sep 6, 2005 | 09:37 PM
ohhiitznik's Avatar
im running 0w40 mobil 1, and it only smokes when I do a hard deccell
Old Sep 6, 2005 | 09:38 PM
ohhiitznik's Avatar
and the exhaust pops but its a muscly popping noise, and only does it a few times.
Old Sep 6, 2005 | 09:39 PM
ohhiitznik's Avatar
but its not like a hard blue smoke, like you can see its like a whitish color.
Old Sep 6, 2005 | 09:45 PM
GDM Z28's Avatar
well is it blue or white? lol...white usually means your getting coolant in your combustion chamber and its burning.....
Old Sep 6, 2005 | 09:47 PM
ohhiitznik's Avatar
its like a light blue. like its burning a little bit of oil on hard deccell, and when i say hard deccel im talkin from 5k down.
Old Sep 6, 2005 | 09:58 PM
GDM Z28's Avatar
how many miles on the car?
Old Sep 6, 2005 | 09:59 PM
ohhiitznik's Avatar
75k on the clock.
Old Sep 6, 2005 | 10:00 PM
ohhiitznik's Avatar
I think its a valve stem seal like your talkin about, itll all get replaced when I do a cam swap, ill replace the whole drivetrain, rockers included. that is after the tranny gets rebuilt, and the clutch gets done
Old Sep 7, 2005 | 01:39 AM
ohhiitznik's Avatar
ttttttt
Old Sep 7, 2005 | 01:44 AM
99SS-T's Avatar
I know what it is. I had the same exact thing. What is happening is that the hoses that go to the valve covers are pullin a mist of oil into the throttle body under hard engine decel. If you remove rhte hoses that go to the TB it will stop doin this. You may also have bad seals but i doubt it. I beat the hell outta me car and have the same miles as you nad not a drop of smoke. GL man
Edit: I also just noticed we have the same car. I have a 99 Camaro SS hugger orange with a 6 spd. You got white leather? GL
John
