After cam install lifter tapping
i dont know how loud your ticking is but a lil ticking is normal
just dont want ya to do all that work for nothing
I did use a hammer. But just tapped a little bit and then tightened the bolt. It worked great....just took a little time!
Did you replace your valve springs? Thats a pretty hefty cam to be using w/ stock springs. If you did replace the valve springs, are they set at the correct pressure? If not, that could cause "clearance" in your valve train and therefore, tapping.
Philip S.
I really don't think the tick is due to low oil pressure. When you install a larger cam than stock, it is not uncommon for the oil pressure to drop like that at idle. I'm not sure why, I just know it does.
BUT.......did you do anything different with the valve springs??
That cam is definitely pushing the limits on stock valve springs. I would start there....
