is it possible to make a 455 ci ls1
Old Sep 8, 2005 | 02:50 PM
J02ws6transam's Avatar
Default is it possible to make a 455 ci ls1
hey guys i am going to make a 427 ls1 motor this winter in my 02 ws6. but i was wondering if you could resleeve the motor and make it a 455. like 427 is really a chevy motor ya know and pontiac had the 455. Now i see that lunati makes a 447 rotating assembly for the ls1, so is there a way to get the extra 8 cubes outa the motor to make it a 455? thanks guys.
Jon
Old Sep 8, 2005 | 02:56 PM
dame's Avatar
MTI put one in a GTO but it was an MID block.......
Old Sep 8, 2005 | 03:07 PM
LSONE's Avatar
technically yes, but probably not worth the money.
https://ls1tech.com/forums/generation-iv-internal-engine/351591-darton-large-bore-ls2-dry-sleeve-here.html
that is the block you would need, bored to 4.155''
and like a 4.2'' stroke to get to 455''
Old Sep 8, 2005 | 03:12 PM
ROCNDAV's Avatar
Lunati does make a 454 kit. You may just have to round up one inch, just like the 382, 396 guys do
Old Sep 8, 2005 | 03:30 PM
sleepersilverado's Avatar
didnt texas speed do it by offset grinding the crank?
Old Sep 8, 2005 | 06:18 PM
i didnt know lunati made a 454 kit, i guess the place i was looking only had up to 447. i will have to look into it, thanks guys.
Jon
Old Sep 8, 2005 | 07:01 PM
ROCNDAV's Avatar
Yeah, I don't think its listed on their website, but they do offer a 4.25" LS1 crank.
At the time I was debating between 427 and 396 (5) , I was told I could also go 454.
Old Sep 8, 2005 | 07:15 PM
JakeFusion's Avatar
Super Hulk Smash
4.2" Bore with the new MID Sleeves and a 4.125" Crank will give you 457. That will make more power than a 455 with a 4.155" bore and 4.2" Crank because of the extra breathing capabilities of the increased bore, not to mention it will rev easier.
Better put a carb type manifold on it and a rectangle port LS7/C5R style head, though, to make a noticeable power improvement over the 427s on something with that many cubes. LSX90 intake and ported LS6 or AFR225 heads are simply too small for an engine that big.
Old Sep 8, 2005 | 07:47 PM
ROCNDAV's Avatar
or put a 4.25 crank on that bad boy and you have a 471
Old Sep 8, 2005 | 08:50 PM
jrp's Avatar
jrp
SN95 Director
MTI used a 4.160 (max bore) Darton MID wetsleeve kit and a custom 4.185 stroke
Old Sep 8, 2005 | 09:05 PM
Ferocity02's Avatar
Would boring an LS1 block that big make it very weak?
Old Sep 8, 2005 | 09:13 PM
JakeFusion's Avatar
Super Hulk Smash
Can't bore the aluminum LS1/6 block because it has iron ductile sleeves in it. The Modular Integrated Deck (MID) of Darton does strengthen it a bit, but just because the sleeve is bulletproof doesnt mean the thin aluminum block behind the thing MID sleeve won't warp on itself and crack somewhere else.
You can safely bore the LQ4/9 block .030" over and sometimes as high as .060" with a sonic test of the block.
The C5R block can be bored to 4.130".
Old Sep 8, 2005 | 09:16 PM
jrp's Avatar
jrp
SN95 Director
no, the iron liners are only about .060 thick.
Old Sep 23, 2005 | 03:22 AM
JarrettL's Avatar
I think you're mistaken. That would be a HUGE crank! Chevy big block style. There's a 4.125" crank and a 4.185" crank and I think Lunati offers them both. The easiest way to get a 455 woud be the 4.160" bore block(either gen III or gen IV but gen III is going to be wet-sleeved=$$$) and a Lunati 4.185" crank. Another alternative would be a 4.200" bore gen III resleeved block and an Eagle 4.100" crank which would give you 454.4ci which would definitely pass as a 455 in my book. If not, after a year or so when all that friction wears on your cylinder walls, you'll have your .1cubic inch.
Old Sep 23, 2005 | 03:25 AM
JarrettL's Avatar
There is a difference between a 382 and a 383. The 382 is a 4.000" crank on a factory bore(3.898") but a 383 is a 4.00" crank on a 3.903" bore.
Old Sep 23, 2005 | 07:21 AM
RevGTO's Avatar
Pontiacerator
Originally Posted by J02ws6transam
hey guys i am going to make a 427 ls1 motor this winter in my 02 ws6. but i was wondering if you could resleeve the motor and make it a 455. like 427 is really a chevy motor ya know and pontiac had the 455. Jon
The Pontiac 428 was actually 427 and had the exact same bore & stroke as the new LS7 - 4.125 x 4.00. So go 427 and call it 428! You could also go 421 with less bore for another good classic Pontiac number.
Old Sep 23, 2005 | 07:52 AM
PREDATOR-Z's Avatar
Pardon me for saying so, but to choose a stroke based on just the fact that Pontiac used to have some is, well, ...******* stupid
Sorry, my apologies, I couldn't restrain myself.
Old Sep 23, 2005 | 08:06 AM
DONAIMIAN's Avatar
I agree, are you spending money on the motor to make the car faster, are or you spending the money on the motor so you can run a special badge.
Old Sep 23, 2005 | 08:15 AM
Bryan @ Speed Inc.'s Avatar
to anyone who wants to know how to get a certain engine size in cubic inches... here is the formula to find out bore and stroke combos and what they would equal...
BORE X BORE X STROKE X .7854 X 8 (or amount of cylinders for anything other than a v-8).
and as far as just wanting to max out an enginge's capability just so you can say you have a 455 is kinda lame to me. but that's just my honest opinioin.
Old Sep 23, 2005 | 08:18 AM
for example... 4.125 x 4.125 x 4 x .7854 x 8 = 427.65 cubic inches. C5-r / LS-7 bore and stroke combo.
