Oil pump removal? Help.
Bolts not loosend yet are the two tranny bolts that go into the pan,
one back upper bolt on driverside,bracket, and the two back bottom bolts under the pan. I have eleven bolts loosened. Trending Topics
^infinity
inch if not more. My fingers aren't fat and I can get into alot of tight spots on are LS1's, but the pickup tube access had to be done by dropping the pan.
