46MPH hesitation
Old Sep 22, 2005 | 10:42 PM
Phoenix 5.7's Avatar
no it doesn't have EGR. they were able to pass emmissions without it with a few other mods. newbs need to know the info b4 they post
Old Sep 25, 2005 | 10:23 PM
AW794's Avatar
I still think it has something to do with the PCV system
Old Sep 28, 2005 | 08:42 AM
white99's Avatar
I cleaned the EGR valve (used like 3/4 a bottle of carb cleaner) and MAF. I still get the hesitation, but not as much.
Old Sep 28, 2005 | 02:28 PM
Ravenous T\A's Avatar
i get it too, I cleaned the IAC holes in the TB and it seemed to help it. Might wanna check if your IAC module is about to go out. my car just started this, im going down the list of possibles...IAC, MAF, Fuel Pump, and now new to the list EGR. I had a problem of Hard Cold & Warm starts but after cleaning the idler air holes she cranks right up.
Links to my posts
https://ls1tech.com/forums/texas-members/386096-idle-driving-issues-need-help.html
https://ls1tech.com/forums/fueling-injection/385968-idles-2000-rpm-s-more.html
maybe give some other views on the culprit.
Old Sep 28, 2005 | 03:49 PM
AW794's Avatar
Noobie question... whats a IAC?
im guessing idler air something?
Old Sep 28, 2005 | 03:53 PM
AW794's Avatar
Oh and i know i am pulling timing... I put a scanner on it. So i think that rules out a TPS issue?
Old Sep 28, 2005 | 03:55 PM
Idle Air Control, its on the Driver side of your TB. Opens and Closes the Two holes inside your TB to control Idle. I hear sometimes they stick due to carbon and gunk. I Cleaned mine with some BG Intake cleaner and it helped a little.
Old Sep 28, 2005 | 04:04 PM
SS44JS's Avatar
I have the same problem, a slight hesitation between 2500 - 3000 rpm will cleaning the maf and erg help?
 Michael S. Palmer
Old Oct 4, 2005 | 04:19 PM
AW794's Avatar
any updates?
Old Oct 4, 2005 | 04:31 PM
well I think my problem was bad gas
Old Oct 4, 2005 | 05:24 PM
FLA02TA's Avatar
Same problem here. I thought it was due to me adding the Loudmouth II exhaust since I noticed it a couple days after I installed it. It only happens to me when I punch it from an on ramp to the interstate. Normal driving at 45-50 mph doesn't have the hesitation.
It's like I lose all my power for a bit but she slowly accelerates to 70 afterwards from about 45mph.
1st to last gear normal driving, no problems. If I'm in say 3rd or 4th then floor it to get on the interstate, she hesitates.
Old Oct 5, 2005 | 06:02 PM
  #32
AW794's Avatar
same problem here FLA02TA
